Wireless Networking Belkin Pre-N notebook card problems
Subject Author Date
Belkin Pre-N notebook card problems J&SB 11-26-05
Posted by J&SB on November 26, 2005, 10:28 pm
I have had a Belkin Pre-N router and a Pre-N notebook card for several
months now. Up until recently, my laptop has been running Windows 2000, and
I was forced to use a free WPA-PSK client available from McAfee in order to
support WPS-PSK security. In any event, I've had rather flawless
connectivity and excellent data rates with the Pre-N using WPA-PSK.
The other day, I decided to upgrade the OS on the laptop to XP(SP2). After
a fresh install of XP, I installed the Pre-N notebook card software and
drivers. Since then, I've had absolutely lousy connectivity either by using
the Belkin application, or by letting Windows manage the wireless
connection. When I do achieve connectivity, it's at a few Kbps - even when
in the same room with the router. Does anyone have any suggestions as to
what may be wrong with my configuration, and what I might do to to correct
it? Thanks.
Posted by John Navas on November 27, 2005, 4:26 am
>it? Thanks.
Signal strength?
Any other networks on the same channel?
Best regards, FAQ FOR CINGULAR WIRELESS
John Navas <http://en.wikibooks.org/wiki/Cingular_Wireless_FAQ>
Posted by Quaoar on November 27, 2005, 8:16 am
> 2000, and I was forced to use a free WPA-PSK client available from
> McAfee in order to support WPS-PSK security. In any event, I've had
> rather flawless connectivity and excellent data rates with the Pre-N
> using WPA-PSK.
> After a fresh install of XP, I installed the Pre-N notebook card
> software and drivers. Since then, I've had absolutely lousy
> connectivity either by using the Belkin application, or by letting
> Windows manage the wireless connection. When I do achieve
> connectivity, it's at a few Kbps - even when in the same room with
> the router. Does anyone have any suggestions as to what may be
> wrong with my configuration, and what I might do to to correct it?
> Thanks.
Google for winsockxpfix.exe and run it to reset the TCP/IP stack. Do
also what has been suggested for firewall, anti-virus, etc. You might
(probably already have done this?) reset the router to basic config
until you get the connection issues resolved. Run the wireless network
wizard sometimes helps if you have been setting up manually. Wireless
Zero Configuration service should be disabled if using the Belkin
utility. Likewise the Belkin utility must not be running of using WZC.
The wireless networking wizard needs WZC.
Check all of the wireless settings: uncheck 802.11x authentication,
select infrastructure only, disable autoconnect to non-preferred
networks. Make sure your network is the only entry in Preferred
networks.
Posted by J&SB on November 27, 2005, 10:33 am
Looks like a combination of 3 things. First off, connectivity was just fine
this morning when I booted up the laptop. There must have been excessive
interference yesterday in the neighborhood. Secondly, I turned off the
Windows firewall and throughput indeed improved. Lastly, changed to AES on
the WPA-PSK and got the most noticeable increase in data rate. Things look
just fine now. Thanks to everyone for their suggestions.
>and I was forced to use a free WPA-PSK client available from McAfee in
>order to support WPS-PSK security. In any event, I've had rather flawless
> After a fresh install of XP, I installed the Pre-N notebook card software
> and drivers. Since then, I've had absolutely lousy connectivity either by
> using the Belkin application, or by letting Windows manage the wireless
> when in the same room with the router. Does anyone have any suggestions
> as to what may be wrong with my configuration, and what I might do to to
> correct it? Thanks.
Posted by me here on November 27, 2005, 10:05 pm
> several months now. Up until recently, my laptop has been running
> Windows 2000, and I was forced to use a free WPA-PSK client available
> from McAfee in order to support WPS-PSK security. In any event, I've
> had rather flawless connectivity and excellent data rates with the
> Thanks.
From my experiences, poor network speed is most often due to firewall
or antivirus settings.
Turn them off and see how it performs.
Eg. Avast antivirus reduces my network speed enormously if the network
scanner module is enabled.
Also make sure that the XP firewall is off.
Cheers
Rob
Similar ThreadsPosted
Belkin PreN Notebook Network card problem February 20, 2007, 11:29 pm
Belkin Pre-N notebook card problems November 26, 2005, 10:28 pm
Belkin Notebook Network Card February 18, 2006, 4:13 am
Belkin Wireless Pre-N 802.11x Pre-N Notebook PC Card Adapter - linux April 30, 2005, 7:24 pm
Belkin wireless g notebook card and telnet test port August 23, 2006, 12:54 pm
Belkin PCI 802.11g desktop card problems and solutions July 30, 2005, 10:11 am
belkin wireless g notebook problem HELP I YOU CAN PLEASE January 1, 2007, 11:09 pm
A Belkin Pre-N router with Belkin Pre-N PCMCIA card : Question January 8, 2005, 7:29 am
Total Wireless card and notebook February 27, 2005, 1:37 am
wireless network card on notebook March 2, 2005, 12:23 am
Notebook Mini PCI card not working June 5, 2005, 8:36 pm
WINXP, D-LINK router, Toshiba Satelliete notebook problems January 19, 2007, 4:52 pm
using Netgear PS401 wireless card in a notebook PC October 28, 2004, 10:00 am
Cannot connect to my Belkin Router from my Belkin Pre-N Card February 5, 2006, 7:19 pm
belkin router problems October 1, 2005, 9:21 pm
