Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Glenn on November 25, 2006, 4:14 am
Please log in for more thread options My Belkin ADSL MIMO Wireless Modem Router Model F5D9630-4 appears to have corrupted firmware installed, The firmware is not available on Belkins website http://www.belkin.com/uk/ I have emailed Belkin 48hrs ago so-far no Response. Firm ware iI'M looking for is 1.00.04 anybody help. Regards Glenn | |||||||||||||
Posted by Nemo on November 25, 2006, 6:36 am
Please log in for more thread options Have you tried resetting it back to factory default this should at least get it working. | |||||||||||||
Posted by Glenn on November 25, 2006, 6:49 am
I have tried that but Im am only re-installing the same corrupted hardware Thanks for your reply | |||||||||||||
Posted by Nemo on November 25, 2006, 8:12 am
If you link your router and computer with a network cable what can you see when you put 192.168.2.1 into internet explorer this is your belkin router address you should at least see some settings if you can't then send it back.. what makes you suspect the firmware is corrupt? you could try loading drivers from previous model I suspect there's not much difference. . > I have tried that but Im am only re-installing the same corrupted hardware
> Thanks for your reply > | |||||||||||||
Posted by Glenn on November 25, 2006, 10:24 am
Hi Nemo I had thought of downloading drivers from my older Belkin F5D7630 but im just being cautious this older product works well with the same settings as the new F5D9630. If i could get a copy of the firmware for the 9630 it woud save me time and trouble although ther is no guarantee that its the problem Regards Glenn > If you link your router and computer with a network cable
> what can you see when you put 192.168.2.1 into internet explorer > this is your belkin router address you should at least see some settings > if you can't then send it back.. > what makes you suspect the firmware is corrupt? > you could try loading drivers from previous model > I suspect there's not much difference. > . >> I have tried that but Im am only re-installing the same corrupted
>> hardware >> Thanks for your reply >> >
Belkin MIMO Firm-ware wanted please
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Regards Glenn
