Wireless Networking Balun for Sector
Subject Author Date
Balun for Sector Knight 09-21-08
|--> Re: Balun for Sector Jeff Liebermann09-21-08
Posted by Knight on September 21, 2008, 8:43 am
Hey guys,
Was wondering what is the smallest coax someone can use to make a
Balun for this Sector antenna.
http://pe2er.nl/wifisector/
Reason is the RG-58 is so short and hard to bend'
Can you use a smaller diameter coax and still have this antena work?
Thanks guys
Pete
Posted by Jeff Liebermann on September 21, 2008, 10:20 am
On Sun, 21 Sep 2008 05:43:31 -0700 (PDT), Knight
Read the article again. The author uses RG-316/u teflon dielectric
cable for the balun. Outside diameter = 0.100". The RG-58a/u is used
for the feed line (which is pushed through a brass tube and soldered
to the PCB reflector). For such short runs, the coax cable losses are
not important.
I use semi-rigid 0.087" diameter coax because it's easy to handle,
easy to solder, no messy braid, and I happen to have some. There are
smaller sizes, but those are far more difficult to handle:
<http://www.micro-coax.com/pages/products/ProductTypes/CableTypes/Semi-RigidCoaxial/EqualTo50ohms/Size.asp>
If you can find one, get a thermal wire stripper for teflon. If not,
use a sharp Exacto knife, or make your own hot wire thermal stripper.
There may be some differences in the strip length of the balun coax.
Length = 0.5 wavelength * velocity_factor
Most of the stuff I use has a measured Vf of 0.70, but there are some
oddities floating around, especially if you buy surplus. Measuring
the Vf might also be helpful if you can't identify the cable.
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by DTC on September 21, 2008, 10:20 am
Time Microwave LMR-100
Posted by Knight on September 21, 2008, 2:30 pm
Jeff not sure what RG-316 is, but is it small like LMR-100 like DTC
says?
Now that would be nice if I can that!
What would be the length to use if in fact I can use LMR-100?
Thanks guys
Pete
Posted by Jeff Liebermann on September 21, 2008, 3:37 pm
On Sun, 21 Sep 2008 11:30:58 -0700 (PDT), Knight
>says?
Both LMR-100 and RG-316/u are about 0.100" in diameter.
LMR-100 is stiffer and does not bend easily. RG-316/u does not have a
foil shield, and therefore bends much easier. Either will suffice.
<http://parts.digikey.com/1/parts/34986-coax-cable-rg316-u-50-ohm-9316-br001.html>
See photo of RG-316/u on bottom of page.
A suitable alternative would be RG-188/u which is 0.110" diameter but
has a tape wound PTFE outer jacked instead of FEP.
The velocity factor of LMR-100 is 0.67.
One wavelength at 2.44 GHz (mid band) is 12.3 cm in free space.
The shield strip length (not the cut length) is:
length = 0.67 * 12.3cm / 2 = 4.12cm
See the diagram for how the balun is built.
Incidentally, I've now built about 6 assorted AMOS/Franklin antennas
including some really weird constructs. They all work just fine,
although the higher gain versions required using a sweep generator to
accurately adjust the center frequency.
Similar ThreadsPosted
Balun for Sector September 21, 2008, 8:43 am
What about a balun? August 13, 2006, 8:06 am
FS: YDI Terabeam Model A2.45LP14 2.4 GHz Vertically Polarized Sector Antenna for WIPOP, two available March 1, 2008, 3:04 pm
FS: YDI Terabeam Model A2.45LP14 2.4 GHz Vertically Polarized Sector Antenna for WIPOP, two available May 10, 2008, 4:22 pm
FS: YDI Terabeam Model A2.45LP14 2.4 GHz Vertically Polarized Sector Antenna for WIPOP, two available June 12, 2008, 1:20 pm
FS: YDI Terabeam Model A2.45LP14 2.4 GHz Vertically Polarized Sector Antenna for WIPOP August 29, 2008, 12:41 pm
