Wireless Networking Automatic configuration
Subject Author Date
Automatic configuration Anbjorn Grindheim 11-24-05
Posted by Anbjorn Grindheim on November 24, 2005, 2:05 pm
Is there a low cost AP which lets me automate configuration through
telnet or simular? I'm specifically looking for a solution where I can
automatically change the WEP key at a regular basis.
AG
Posted by David Taylor on November 24, 2005, 1:51 pm
ag_news@datamorgana.no says...
Have to ask, why not buy a low cost AP which supports WPA or 802.1x
instead and then you wouldn't have to!
David.
Posted by Anbjorn Grindheim on November 24, 2005, 3:26 pm
Initially, I thought about using a radius server, but I found out that
those users that have devices that support it find it to difficult to
set it up, and several users have devices that do not support it. I also
need to give guests access to my secured network without compromising
security (e.g. giving away a shared password). Ideally, I want to give
guests an option to quickly log on to my encrypted network without
knowing the WEP key or WPA shared password, but a compromise could be to
hand out the key and change it daily. I would be glad to hear other
solutions, though.
AG
Posted by David Taylor on November 24, 2005, 2:35 pm
What problem are you trying to solve here? Access to the WLAN or
security of the transit data or both?
So buy a hotspot solution or a cheap WRT54G on Ebay and load up some
hotspot firmware. A WEP key by its very nature *is* a shared key. The
only way you'll move forward from that away from a shared key is a
RADIUS solution, hotspot solution or some other expensive solution.
That's the problem, how are you going to poke a WEP key into unknown
devices in a simple manner? If all the devices were equal then you'd
have a first step but then how would you do that across the LAN without
connectivity? The only way that you might be able to do it is with an
AP that supports multiple SSID's/VLAN's where the user connects to an
unauthenticated VLAN, gets a client that pokes the key or otherwise
gives them the necessary information. Then when they reconnect, they
connect to the other SSID and end up on the other VLAN. If they had
accounts, they that information could be on a secured webpage but then
if you're doing all this, I can't help but think that the RADIUS server
all of a sudden becomes the better idea?
David.
Posted by David WE Roberts on November 24, 2005, 10:58 pm
Don't know about low cost but I can telnet into my Belking wireless ADSL
router and manage that.
ISTR it is based on a Connexant board/chip.
If you look at the Broadband Router version this may offer what you want.
Just look for a AP/Router with a serial port (do they still do this?) or a
Telnet connection.
Connexant seem to generally support this.
HTH
Dave R
Similar ThreadsPosted
Automatic configuration November 24, 2005, 2:05 pm
automatic fallback January 29, 2005, 6:46 am
Looking for AP with POE and Automatic Restart Capability August 30, 2006, 6:45 am
Help with Netgear Router (Says Automatic) June 20, 2007, 9:05 am
Mac address & hostname automatic randomizer freeware for Windows December 22, 2008, 1:10 am
Re: Mac address & hostname automatic randomizer freeware for Windows December 22, 2008, 8:42 pm
Re: Mac address & hostname automatic randomizer freeware for Windows December 22, 2008, 9:46 pm
Re: Mac address & hostname automatic randomizer freeware for Windows December 23, 2008, 3:27 am
Re: Mac address & hostname automatic randomizer freeware for Windows December 23, 2008, 3:33 am
Re: Mac address & hostname automatic randomizer freeware for Windows December 23, 2008, 3:38 am
Re: Mac address & hostname automatic randomizer freeware for Windows December 23, 2008, 12:10 pm
automatic disabling of wireless connection while connected to wired net: howto? September 26, 2005, 2:27 pm
Automatic speed test on all the available WiFi networds to select the faster? March 28, 2007, 2:51 pm
configuration of wifi on Win XP sp2 April 11, 2005, 9:03 am
network configuration help July 20, 2005, 11:49 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
