Wireless Networking Access point or powerline range extender to cover an higher range ???
Subject Author Date
Access point or powerline range extender to cover an higher range ??? etantonio 01-20-07
Posted by etantonio on January 20, 2007, 9:37 am
I have a mimo wireless router , the netgear DG834PN ,
I've to cover several apartments and this in no more sufficient for
this,
so now I'm thinking to expand the network but I don't know how, my
ideas :
1) to buy a powerline range extender
http://www.netgear.com/Products/PowerlineNetworking/PowerlineWirelessAccessPoints/WGXB102.aspx
2) to buy a repeater, but I've no idea of which one
3) to buy an access point and configure it like a repeater
can you help me to find the right solution ??
Thanks
Antonio
www.etantonio.it
Posted by Peter Pan on January 20, 2007, 2:02 pm
etantonio wrote:
> Hi,
> this,
> ideas :
> Thanks
> Antonio
> www.etantonio.it
Consider these instead (same company, different page/link)...
At
http://www.netgear.com/Products/PowerlineNetworking/PowerlineWirelessAccessPoints.aspx
They give details on their powerline wireless access point....
Basically, for about $130, for two units, one plugs into the modem or
router, the other plugs into almost any electric outlet (usually on the same
transformer, very rare to ever have multiple drops for one home/apartment),
and transmits the signal over the powrline at 54 Mbps, to the second unit
which is it's own access point.. Can be used directly off the cable/dsl
modem, or in my case, I have it plugged into my linksys wireless router
instead (giving me two networks)..
Beauty of it is, no cables, no wiring, just plug the stuff in, and when you
move unplug it and take it with you.. However there is a bad part, it costs
a bit more than just a wireless router (probably $50-$60 more)... Don't
know what your economic circumstances are, but it was the best extra few
bucks I ever spent.. During the nice months of the year, I just plug it in
to one of the exterior ac sockets and use my PDA and laptops in the back
yard.
HOWEVER, I have no idea if the power in your area is the same as the US
(they have seperate pages for non us countries), so you maye have to get
there after you select a country...
Posted by Mark McIntyre on January 20, 2007, 2:41 pm
On 20 Jan 2007 06:37:54 -0800, in alt.internet.wireless , "etantonio"
>Hi,
>this,
>ideas :
Can you run some CAT5 around the complex? If so, I would probably run
a few cables to key points and install a few cheap APs.
Yes, that would achieve the same thing. Restricted bandwidth tho (even
the fastest Powerline kit is rated at 85Mb and throughput seems
realistically to be significantly lower).
Nor me. Bear in mind that each repeater halves the bandwidth.
Mark McIntyre
Posted by John Navas on January 25, 2007, 1:15 pm
>this,
>ideas :
Good idea, but may not work unless the apartments are on the same power.
Try before you buy.
In general, stick with the same brand.
Same as (2).
4) Try high-gain directional antennas or reflectors in the apartments.
5) Consider coax networking if all apartments share the same coax (TV
cable) system.
6) Consider pulling CAT5 Ethernet cable to the apartments.
Best regards, FAQ for Wireless Internet: <http://Wireless.wikia.com>
John Navas FAQ for Wi-Fi: <http://wireless.wikia.com/wiki/Wi-Fi>
Wi-Fi How To: <http://wireless.wikia.com/wiki/Wi-Fi_HowTo>
Fixes to Wi-Fi Problems: <http://wireless.wikia.com/wiki/Wi-Fi_Fixes>
Similar ThreadsPosted
Access point or powerline range extender to cover an higher range ??? January 20, 2007, 9:37 am
Extending Access Point Range wirelessly April 30, 2005, 6:14 am
recommend me a long range access point July 27, 2007, 8:48 am
Powerline Adapters to extend range??? August 21, 2007, 1:59 pm
Extend Wi-fi Range Using WGR614 wi-fi router & WG602 access point?? December 4, 2006, 9:54 pm
Range Extender May 1, 2008, 5:30 pm
WGR614 as range extender / WAP January 2, 2005, 2:38 am
Range extender antenna kit FS January 12, 2005, 12:22 am
Range extender for BEFW11S4 March 4, 2005, 12:37 pm
Extending Range with WDS / extender August 7, 2007, 6:28 am
Wireless Range Extender??? January 26, 2008, 11:25 pm
Linksys Range Extender Question March 1, 2005, 2:17 pm
Help with Gateway Router and Range Extender August 13, 2005, 4:33 pm
What is Linksys range extender (WRE54G) December 30, 2005, 4:43 am
U S Robotics MAXg Range Extender March 5, 2007, 5:37 am
