Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by John Navas on September 18, 2006, 12:25 pm
Please log in for more thread options SUMMARY: WPA-PSK is vulnerable to offline attack. TO AVOID THE PROBLEM: USE A PASSPHRASE WITH MORE THAN 20 CHARACTERS. Examples: BAD: "vintage wine" GOOD: "floor hiking dirt ocean" (pick your own words, even longer is better) FOR HIGH SECURITY, USE MORE THAN 32 CHARACTERS. BACKGROUND: Weakness in Passphrase Choice in WPA Interface By Glenn Fleishman By Robert Moskowitz Senior Technical Director ICSA Labs, a division of TruSecure Corp <http://wifinetnews.com/archives/002452.html>
... The offline PSK dictionary attack ... Just about any 8-character string a user may select will be in the dictionary. As the standard states, passphrases longer than 20 characters are needed to start deterring attacks. This is considerably longer than most people will be willing to use. This offline attack should be easier to execute than the WEP attacks. ... Using Random values for the PSK The PSK MAY be a 256-bit (64 hexadecimal) random number. This is a large number for human entry; 20 character passphrases are considered too long for entry. Given the nature of the attack against the 4-Way Handshake, a PSK with only 128 bits of security is really sufficient, and in fact against current brute-strength attacks, 96 bits SHOULD be adequate. This is still larger than a large passphrase ... ... Summary ... Pre-Shared Keying is provided in the standard to simplify deployments in small, low risk, networks. The risk of using PSKs against internal attacks is almost as bad as WEP. The risk of using passphrase based PSKs against external attacks is greater than using WEP. Thus the only value PSK has is if only truly random keys are used, or for deploy testing of basic WPA or 802.11i functions. PSK should ONLY be used if this is fully understood by the deployers. See also: Passphrase Flaw Exposed in WPA Wireless Security <http://www.technewsworld.com/story/32070.html>
Wi-Fi Protected Access. Security in pre-shared key mode <http://en.wikipedia.org/wiki/Wi-Fi_Protected_Access>
Cracking Wi-Fi Protected Access (WPA) <http://www.ciscopress.com/articles/article.asp?p=369221>
<http://www.ciscopress.com/articles/article.asp?p=370636&rl=1> WPA Cracker <http://www.tinypeap.com/html/wpa_cracker.html>
| Similar Threads | Posted |
| ALERT: WPA isn't necessarily secure | September 1, 2006, 11:26 am |
| ALERT: WPA isn't necessarily secure | September 18, 2006, 12:25 pm |
| ALERT: WPA isn't necessarily secure | October 3, 2006, 1:04 pm |
| ALERT: WPA isn't necessarily secure | October 16, 2006, 4:59 pm |
| ALERT: WPA isn't necessarily secure | November 6, 2006, 10:18 am |
| ALERT: WPA isn't necessarily secure | November 20, 2006, 11:47 am |
| ALERT: WPA isn't necessarily secure | December 4, 2006, 8:30 pm |
| ALERT: WPA isn't necessarily secure | December 20, 2006, 9:51 pm |
| ALERT: WPA isn't necessarily secure | January 2, 2007, 1:43 am |
| ALERT: WPA isn't necessarily secure | January 16, 2007, 12:53 am |
| ALERT: WPA isn't necessarily secure | February 5, 2007, 10:43 am |
| ALERT: WPA isn't necessarily secure | March 5, 2007, 9:23 am |
| ALERT: WPA isn't necessarily secure | March 19, 2007, 9:53 am |
| ALERT: WPA isn't necessarily secure | April 2, 2007, 8:29 pm |
| ALERT: WPA isn't necessarily secure | April 18, 2007, 3:07 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
