~ Does any one know a a AP that supports 802.11A only, or a A/B/G one that ~ can have the 2.4G transeiver turned off? If found severa A only ~ AP's online but none of them are sold anymore. ~ ~ The best would be one that supports PoE ~ ~ We want to use wireless for some of our stuff here, but we are a R&D ~ company wokring on 2.4G wireless products and the do not want the 2.4G ~ band flodded while they test our products. ~ ~ -Dan
Our AP1200 can be bought with just an 802.11a radio. although if you don't need the removable antennas, you could use an AP1130AG and just turn off the
2.4GHz radio - this would be cheaper (and prettier!)1130AG:
