snipped-for-privacy@apaflo.com (Floyd L. Davidson) wrote in news: snipped-for-privacy@barrow.com:
I see no evidence of that based on the user manual I went on line at
I don't use the product and reading the information about the 54G, it didn't appear that it was doing anything more that the other Linksys routers out of the box.
I never said that I did know a whole lot about a 54G NAT router or IPtables since I don't have the need to use either one of them.
I use a Watchguard and I used a 11S4 and some other Linksys routers that other people have had me take a look at and none of them where then are now FW appliances.
And again, you should drop a line at comp.secuity.friewall about a Linksys 54G NAT router, which now is using a packet filter in the firmware.
And I briefly looked at the FW on Linux and saw what I wanted and disabled it since the machine is setting behind the WG.
Hey, just like you I am no expert at it either. There have been posts made about D-link(s) and Netgear routers *high-end* models with most of the bells on them that fall into the category of a network FW that the
54G seems to fall into based on the link I posted.For the 54G I guess you do. ;-)
I have used other Linksys routers so the 54G has a little more going for it now. Hey what can I say about it?
Is that right?
I am not using the 54g nor did I read any of your links so it took me a minute to figure out what the Hell you were talking about.
And nether am I which I'll assume is based on your knowledge of IPtables. However, since I am here using the WG product and used the FW services provided on the product, I think I know a little something.
Well I have not paid to much attention to the 54G, since I don't have one sitting in front of me.
To be honest, I was not paying that mach attention to any of your conversation. And for me to make a point was not the case.
I looked at the user manual at the site so I may have I missed it and I did come through the FW pages too. It didn't appear to be able to set the rules to the degree that I can with the WG. But it does have some rules that can be set.
So where did I say not to use a 54G?
However, I'll never use a wireless NAT router in the trusted zone again nor would I ever use a wireless WG Firebox SOHO 6 appliance either.
I doubt it.
So what that they are all running Linux and all NAT routers are not running FW software.
No doubt, on the other hand that 54g may be better than I thought it was but it cannot match the WG FW appliance.
And some NAT routers have more bells a whistle than others and they cannot out class a FW appliance. The can come close.
Hey I am no expert in FW(s) and I continue to learn. IPtables is just a packet filter running with Linux. MS has one too called IPsec and I have used it to supplement the Linksys (no FW) NAT router I use to use and I know it well. :)
BTW, I am through with the conversation about the 54G NAT router and IPtables. :)
Duane :)
