Hello friends, I have a Cisco Access point 1242AG. It has the capability to transmit
108Mbps using the two 2.4 GHz antennas, but I am not sure if the actual speed is 108 because I can not find a setting where I can tell the AP to work at 108, the only configuration I can find is on - Network Interfaces | Radio0-802.11G | settings - "Recive antenna: Diversity" and "Transmit Antenna: Diversity".Is that enough to make it work at 108, or do I have to make any other configuration? (I can't find it)
Many thanks
