Thanks for all the previous help. I now have two wrt54gl routers running ddwrt in wirless bridge mode. Everyhting seems to work. What I am now wanting to do is put some bigger antennas on these routers to make a better connection.
Just wondering what the major differences are if I go to a 2.4 GHz 24 dBi High Performance Die Cast Reflector Grid Wireless LAN Antenna - Model: HG2424G
How much performance do you loose to cable length?? The reason I ask is for the one router in the office I have access to a window, but I need to go to the roof for the antenna to be mounted and the distance is around 20-30ft.
Are there powered versions of antennas for around $60
Thanks in advance
BRyon
begin 666 hotspot_icon.gif M1TE&.#EA6@`>`( ``/_______R'Y! 04`/\`+ ````!:`!X```(UA(^IR^T/ MHYRTVHNSWKS[#X;B2);FB:;JRK;N"\?R3-?VC>?ZSO?^#PP*A\2B\8A,*I=, $9@$`.P`` ` end
