Hi! I'm building a WiFi home network and I need to make a signal repeater (relay?) using PC with 2 PCI Prism 2.5 cards. Is it possible?
It should be a "transparent" device that will take the signal from the top of the roof and transport it into my apartment (and vice versa). The ultimate goal is to connect laptops to the AP which can't be seen from inside of my apartment (but I see it clearly from the roof) and the interval between roof and AP is almost 800m (so even if I could see the Access Point from my apartment, wifi devices from the laptops won't reach it). I don't want to make AP or anything like that. I want to simple connect my home devices to master AP at the lowest cost (I already have a old PC Box and 2 Prism Cards).
