2 Wireless Cards on one laptop
Can I have 2 wireless cards installed on my comp and use them to access two different wireless networks at the same time?
I use a wireless network at my office but it does'nt have internet. I want to connect to a local wireless provider for internet. But each time I need to do that, I have to change my wireless network settings.
My Dell 700M has Intel Pro/Wireless 2200BG and I have installed a DWL-G630 wireless card. I haven't been able to get the DLink to receive a signal at all, although it is installed correctly. The Intel works just the way it always have- just fine.
Can I use two on one comp? If so, any ideas how?
Thank you all for your help.
KH
youthminman
The only problem with two PC-Cards is that the antenna sections preclude adding a second card to a two-card slot. You will have to use an USB wireless for the second connection.
Q
Quaoar
Yes.
Doc
John H. Holliday
No, because the IW2200 is internal (mini-PCI), so it can work, but then there's routing issues. It should be possible - specifics would need us to know what OS you use. What happens if you shut off the internal transmitter (fn-F2 on my inspiron - I would expect yours to have a similar key), then insert the D-Link? If you still can't get a signal, you have a problem with your card.
Derek Broughton
I had two PC Cards in my Dell laptop. One was an SMC card that is pretty flat, and the other was an Orinoco with an antenna hump. I used this to connect to two different networks at the same time. I don't think I used ICS across my "bridge", though.
dold
Had another brain fart - you specifically stated the mini-PCI card.
Q
Quaoar
He wont have to, it just depends on how slim the antennas are. Netgear MA401 for example, is very slim and takes up no more than one slot.
I can run a Senao with a Cisco or an Orinoco at the same time.
David Taylor
Perhaps one card and microsofts Virtual WiFi
VirtualWiFi allows a user to simultaneously connect his machine to multiple wireless networks using just one WLAN card.
bumtracks
I have been connected with a Cardbus card and the internal card at the same time, using a Buffalo card and their software. So it is possible.
Did you try turning off the internal wireless to see if the D-Link card works on its own?
SMS
Yes I read that the other day. I can see the network admins just loving that one, I don't think!
David.
David Taylor
I did try that and it didn't work on its own.
KH
youthminman
