I want to share an internet connection but have two separate LANs so computers from one LAN can't access shared files on computers on the other LAN, i.e.
/-->LAN1 Modem-->Router1-- \\-->Router2-->LAN2
Both LANs will have static and dynamic IP addresses.
Router1 has the following setup: Router Address: 192.168.1.254 Subnet Mask: 255.255.255.0 DHCP Range: 192.168.1.64 - 253 Default Gateway: 192.168.1.254
Router2 is currently setup like this: Router Address: 172.168.1.1 Subnet Mask: 255.255.255.0 DHCP Range: 172.168.1.100 - 149 Default Gateway: 172.168.1.1
Router1 and Router2 are connected together with a CAT5 cable using a LAN (not WAN) port on each side.
However, I can't access the internet from a computer connected to LAN2. How do I setup Router 2 correctly? If it matters it's a Linksys WRT54GC.
Thanks
