Wireless bridge. 802.11g. 75 yards is a very short distance. I suggest a pair of Linksys WAP54G boxes running in bridge mode. You will need to install a pair of 8dBi or 12dBi patch (panel) antennas to improve the signal strength. Make absolutely sure you have line of sight with no obstructions, moving obstructions (cars and trucks), or trees in the path. You'll get about 20-25Mbits/sec thruput. If this is not enough, and you don't mind spending money, 5.6GHz proprietary bridging will go much faster. For example, Proxim Quickbridge 60 will do 45Mbits/sec full duplex for about $4,000/pair (including integrated antennas).
Bridging is transparent to Microsoft services. You will end up with essentially an extension cord for your ethernet. Everything will appear as one big network. If you set the bridge to pass broadcasts, you can use a single DHCP server, and Windoze browsing will work as expected.
