- Vote on answer
- posted
19 years ago
Hi, I have 2 computers (a desktop and a laptop) and a wireless router. The desktop is connected to internet (through USB) and to the router (via ethernet). The laptop has a WiFi connection to the router. The IPs and operating systems are the following: desktop: 192.168.0.1 (Win2000) router: 192.168.0.2 laptop: 192.168.0.3 (WinXP) The netmask is 255.255.255.0. I can ping from one computer to another and from one computer to the router and can share folders between the two computers, but cannot access Internet with the laptop. I have already enabled on the desktop the option that allows the Internet connection to be shared. If I ping some srever (like
Normally you go from modem to router wan then from router LAN ports to your desktop. Can you hook your router wan port to the modem with an Ethernet cable ?
if not, desktop Ethernet plugs into a LAN port on the router and not wan port
Since your router isn't doing the talking to the internet, you'll probably need to set your laptop to use the other PC as the default gateway. By default its probably set to the router.
Try this solution:
I Have a USB Broadband modem connected to my desktop and want to share my internect connection. How do I do this?
You must run and internet sharing proxy server on your computer that is connected to the USB modem.
Check out some of these programs:
This solution works just fine!!! I noticed that none of the proxies you suggested is for free, unless very strict limitations on the number of users are set (the best one under this point of view is CCProxy, which allows 3 users). Do you know of any proxy server that is for free and allows a larger amount of users? Thanks, Marco
"Robert Jacobs" ha scritto nel messaggio news:g_xOd.18357$Dc.4255@trnddc06...
(snippage)
The user limitations are unlikely to be a problem for home users (its the number of computers really), but anyway Windows contains free proxying software - read up on "Internet Connection Sharing" aka ICS.
"Robert Jacobs" wrote in news:0DXOd.15170$uc.12010@trnddc05:
Whatever makes you think that? ICS will most certainly work in the OP's configuration where the incoming connection is via a USB ADSL modem.
Whether it's the best design is another discussion...
Hope this helps
Well, I never got it to work with a USB Modem... And have tried many times.....
"Robert Jacobs" wrote in news:u%1Pd.26070$uc.11618@trnddc03:
Your earlier post said: "ICS will only work on an ethernet connection, not a USB connection" Please do not make such authoritative-sounding statements when they are simply not correct.
It works fine, alhough I wouldn't recommend it as a 'good' solution.
Kind regards
Actually it'll work on any sort of network connection. I used it successfully on a dialup for quite a while.
It works. Never mind ICS for now, you can simply bridge between USB and ethernet.
