2 Basic Wired-Wireless Connection Questions
Threaded View
I have a B-type wireless router with 4 additional ports.  My typical
wireless connection is:
o  Wireless Signal Strength:  "Excellent"
o  Network Connection Speed: 11 Mbps
o  Internet Download Speed: 2,600-2,800 mbps
(1) Is there any reason to connect to my network by a CAT-5 cable, instead
of the wireless connection, when I am working in the room with the router?
(2) Is there any reason to connect to my network by both a CAT-5 cable and
the wireless connection when I am working in the room with the router?
TIA!
Steve
gfrx92y@yahoo.com
Note:  Remove the "x" in my email address above to send me an email message.
Re: 2 Basic Wired-Wireless Connection Questions
(1) no and (2) no.
The wireless speed to your router is faster than the speed you have to the
internet - so it makes no difference.
If, on the other hand - you were doing file sharing, backups, etc over your
home network to other computers on your home network - then the wired speed
would be much much faster than the wireless speed..
> TIA!
> Steve
> gfrx92y@yahoo.com
> message.
Thanks!
> (1) no and (2) no.
> your home network to other computers on your home network - then the wired
> speed would be much much faster than the wireless speed..
>> instead
>> router?
>> and
>> TIA!
>> Steve
>> gfrx92y@yahoo.com
>> message.
Site Timeline
