I've ordered a laptop with an 11n wifi card. I'd appreciate a recommendation for a 4-port router with 11n capability. I've read about MIMO, and if it increases the distance over 11n, and if I can get a MIMO 11n router then even better. Cost isn't the main factor here, having a firewall, being easy to use and reliable, and distance is.
Thanks for any help.
Chip
