Voice-Over-IP voip phone setup
Subject Author Date
voip phone setup rob 03-09-05
Posted by rob on March 9, 2005, 5:46 pm
i am registered with sipgate, and want to set up a siemens ip phone.
i cant find any specific instructions for this phone, but guess there
must be certain standard parameters that the phone needs in order to
connect to my network/broadband and make calls via sipgate.
can anyone point me to any info?
TIA.
Posted by Ivor Jones on March 10, 2005, 2:10 am
I don't know the device you have, but there are a few basic requirements
to setup a phone/ATA for Sipgate.
Firstly, and I know this may sound silly, but ensure your device supports
the SIP protocol. Not all VoIP uses SIP and some devices don't support it.
Assuming your device supports SIP, you need to enter the setup options,
usually via a web interface or sometimes by using DTMF tones on the phone.
You'll have to read the manual to determine how to do this for your
device.
Once in the setup, set the SIP port to 5060 and if the option is present
the RTP port to 5004. Set the STUN server address to
stun.sipgate.net:10000.
Set the device to use a static IP if possible, if not you can use DHCP but
it may possibly be a source of problems. On the other hand it may work
fine with DHCP enabled (my Sipura does) but some devices like a static IP.
The basic setup above should work for most devices. If it doesn't, you may
need to forward ports 5004, 5060 and 10000 to the IP address of your
device (this is one reason why a static IP is useful). Also you may need
to set the DMZ of your router to the IP address of the device as well.
Hope this helps, let me know. Email me direct if you prefer.
Ivor
(replace 'invalid' with 'com' in sending address to reply direct)
Posted by Rob Walford on March 9, 2005, 6:17 pm
thanks very much for that, sounds straight forward enough. I'll try
that out.
If the sipgate soft-phone works ok, then is it likely that my router
will still need configuring (port forwarding etc) for a hard-phone?
Posted by Ivor Jones on March 10, 2005, 3:13 am
If you can use X-Lite then a hardware phone or ATA should work, but yes
you may need to set up a DMZ or port forwarding. Try it and see, let us
know here how you get on. If you want to do any tests, email me.
Ivor
Posted by Rob Walford on March 16, 2005, 2:03 pm
I'm not having much luck.
Here are the settings the phone is asking for:
Terminal number:
Terminal name:
Register by terminal name:
SIP routing:  Server Gateway Direct
Registrar IP address or DNS name:
Server IP address or DNS name:
Gateway IP address or DNS name:
Outbound proxy:
Default OBP domain:
SIP transport:  UDP TCP
SIP session timer enabled:
SIP session timer value (1800-3600):  seconds
Registration timer value:  seconds
SIP realm:
SIP user ID:
New SIP password:
Confirm SIP password:
Beep on SIP server error:
Message Waiting IP address or DNS name:
Emergency number:
Voicemail number:
Branding/identity name
Thanks in anticipation.
Similar ThreadsPosted
voip phone setup March 9, 2005, 5:46 pm
Configuration for setup: ISDN - Cisco 2821 - SIP Phone October 12, 2006, 10:48 am
Advice for a new VoIP Setup June 30, 2005, 5:12 pm
Simple VOIP setup April 16, 2005, 7:51 pm
Setup a VoIP<--->PSTN Gateway November 30, 2004, 5:27 pm
Need Advice for VoIP hardware setup February 4, 2005, 3:48 am
Asterisk VOIP setup (on the office side) May 20, 2005, 2:18 am
Small Office Voip setup - linksys ip pbx August 7, 2006, 11:48 pm
How to setup February 16, 2008, 5:34 am
how to setup FXO with PABX? July 24, 2005, 12:28 am
setup 2 SPA-3102 for p2p over LAN May 14, 2007, 3:07 pm
Testing a new setup - Zoom X5V December 18, 2004, 8:52 pm
How to setup an 2 isr router 28xx with FXO-FXS VIC Cards? Need Help! July 22, 2005, 4:49 am
Facetime setup protocol analysis? June 26, 2010, 10:26 am
NEWBIE HELP asterisk@home + Broadvoice setup July 11, 2005, 2:20 pm
Latest PostsForumRSS
NEWS: Samsung takes on the Apple iPad with the 7 inch Galaxy... Wireless Networking
c3560 port configuration Cisco Systems
Broadband 2010: A Big Slowdown [telecom] General Telecommunications Forum
Control Hot Water Circ Pump With X10? General Home Automation
Official Course CCNP TSHOOT 642-832 / Foundation Learning Gu... Cisco Certification
Speedflow Communications Honored for Innovation Voice-Over-IP
USB _to_ RJ45 (not from) connection Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
New Discovery about WDM LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
