I am looking for an Internet Telephony application that can be used to send a previously recorded sound file to another phone (land line or cell phone).
Can anyone help?
Regards, Christian // Berlin // Germany.
Can anyone help?
You're looking for an auto-dialer that uses some form of Voip instead of landlines?
Check into Pronexus.com. they have VOIP capabilities using Intel's HMP. I currently use their ISDN interface to make a few million calls a month. and am in the process of changing over to SIP.
If you are any type of VB programmer you can code the application yourself, if not you can purchase their autodialer application.
Jonathan Roberts schrieb:
I am looking for some kind of dialer that can play a soundfile to a VOIP line. Normal land line (ISDN/analog) would be ok, too. But since I got rid of my old modem and ordered ADSL I have no phone at home instead of my cell phone.
If we come to a VOIP based solution, it should be able to call a standard telephone line.
So I am seeking for Skype with "Play .WAV" capabilities. ;-)
An Asterisk PBX can do this. It may be overkill for what you want. Some links regarding this are:
Good luck!
Jonathan
Not to forget
Not sure if this applies to your geography, but ViaTalk allows for broadcasting calls (up to 20 recipients, up to 10 times a month), but you have to record it with a handset.
Mit freundlichen Gruessen,
Thomas
