I was just wondering if any voice over IP hardware products can work on a local area network that is not be connected to the Internet. For instance, if you have two of your voice over IP routers connected to one another using a crossover cable, is there a way that two phones connected to them can talk to one another?
equipment does this, though I haven't played with any of them directly. Most ATAs can't be connected back-to-back, though you could set up a cheap TrixBox (nee Asterisk@Home) server to connect them.
Many ATAs are locked to a specific vendor, and won't work outside their system, so it depends if you have hardware kicking around that you think you want to use...
From memory, SIP can work peer-to-peer like this, if you connect by IP address rather than by name. You won't be able to do fancy things like conferencing but you should get a connection.
If you buy ATA's from best buy or somethign like that, then they will be locked to a specific vendor. You can always buy them from other resellers if you want unlocked devices.
We buy and sell new/used networking equipment. Please contact me if you have any offers or are interested in buying *
** GUARANTEED REAL CISCO, in stock! ALL prices in USD **
50 x CP-7940G= NEW IN BOX @ $260/each
50 x CP-7960G= NEW IN BOX @ $320/each
2 x CISCO1760 (64D/32F) USED @ $500.00
1 x CISCO1760-VPN/K9 (96D/32F) USED @ $650.00
1 x CISCO3640 (64D/32F) USED @ $375.00
5 x CISCO7206VXR= [chassis with single AC power ONLY] NEW IN BOX @ $3800/each
20 x NM-2FE2W USED @ $550/each
2 x NPE-G1= NEW IN BOX @ $9000/each
10 x PVDM-12 USED @ $120/each
6 x PVDM2-8 USED @ $240/each
20 x PVDM2-16 USED @ $300/each
20 x PVDM2-32 USED @ $850/each
10 x PVDM2-48 USED @ $1000/each
1 x VG224 NEW IN BOX $3600
2 x VG248 NEW IN BOX $5000/each
Rick Truong TruTech Systems AIM: ricktrutek E-Mail: rick at trutechsystems dot net
