Hi
Is there a softphone ( opensource, freeware, or trial version) with G.
729 codec ?Hi
729 codec ?Thank you
Firefly
Is there an IP phone speaking H.323 ?
"Firefly" permits use of a G.729 codec built from 'evaluation' sources available on the 'net. I wrote a wiki entry on 'voip-info.org' some time ago describing the procedure to build and use G.729 with 'firefly'.
Regards,
Michael
I presume that you are replying to this message:
Sorry, you didn't specify protocol in you O.P.; I only use SIP ;)
Michael
Finaly I found what I need
But the problem is that it runs only on Windows Are there similar product that run on linux?
You're probably aware, but I thought it worth a reminder: Most ATAs (analog telephone adapters) support H.323 protocol, and these days with Ebay, they can be had very cheaply. Sometimes in the range of 10 bucks USED. That allows you to go to a Goodwill or Salvation army thrift store, buy a 99cent discarded old fashioned analog phone, and be up and running with your choice of protocols. I have several cordless phones throughout my home all running on one of these ATAs, and I get superb telephone call quality for ALMOST...:-) free. I do pay 99 cents/month to have an IP local incomming phone number, and I pay a penny and half/minute for outgoing calls.
You might REQUIRE a soft phone, and in that case, simply disregard this message....:-)
