Hi All,
Is there a softphone that supports the g723 codec or the g729 codec. The Xten phone does not seem to support it.
thanks anand
Hi All,
thanks anand
I was looking at the adoreinfotech's softphone, however no where on their site they mention the cost of it.
Has anybody used their phone ?
Is is possible to use adoreinfotechs softphone with a sipphone account or a fwd account ?
I believe that the paid version of XTen uses 729 (and 723) but is no longer sold.
SJlabs softphone supports 729.
SJPhone which i dowloaded from FWD does not have the option of changing codecs, I think 729 is only available in the paid version. I think I have just two options to purchase xten or sjphone. The reason I want
729 or 723 is because I want to use this softphone over a dialup connection. Any idea how g729 performs over a dialup connection ?thanks anand
Thanks a lot ! Would try some tests
It only supports SIP. SIP minutes are available from numerous sources. One good site which I sometimes use is
You will need minutes for use calling PSTN lines. Sipphone acts as your gateway and service provider.
If you use FWD, why not use SJPhone? They have a ready-made FWD profile that will make configuration simple. I use SJPhone with my Vonage account---- no problems, whatsoever. Registration is *FREE*. A screenshot of the Vonaage skin is here:
I have no experience with SIP over dialup. I do feel that voice quality is generally better with the SJ product than using XTen.
The quality of a dialup connection can vary widely. I would suggest that you test voip over dialup to see if it is even workable.
