Hello,
I have 2 SPA-3102 units and I am trying to configure them so I can make p2p calls via a private LAN and have analog phones connected to both of them sharing a single POTS (for incoming and outgoing calls) line connnected to only one of them.
Hardware and connection I curently have:
1) Two spa-3102 each with an analog phone connected to them 2) One of the spa-3102 is connected to a POTS phone line 3) Both spa-3102s are connected together via a private wifi LANWhat I would like to be able to use this for:
1) make p2p calls between the two analog phones connected to each spa-3102 kind of like an intercom 2) incoming calls on the POTS line should ring both analog phones on both spa-3102s 3) Both analog phones should be able to make outgoing calls using the single POTS line connected to one of the spa-3102Before someone asks, the reason for all this is that each spa-3102 is in a separate building that cannot be wired together but they are linked with a wifi network and I want the two building to use the one POTS line available in only one of the buildings and have the possibility to communicate p2p between the two buildings.
I am new to VOIP and have spent a couple of days searching for info/ tutorials on the net but cannot find anything similar to what I want to do. The wizards I found all assume you use a Voip provider in some way.
Any help/pointers tutorial or book references appreciated
Thank You
Patrick Robin
