Could you please advise where can I get a firmware version for the LINKSYS - SPA 2102 that works fine. If you have it could you please send it. It seems that the latest LAN version is not working properly. Thanks
Juan G. Casta=F1eda
Juan G. Casta=F1eda
Juan:
I have about 2 dozen Linksys/Sipura SPAs (at least one is a 2102) and they are all working properly.
What do you mean by "the LAN version"? What the heck is a "LAN version"?
I also went through the route of trying to find "the latest firmware" and every single time the problem was something else (a buggy Asterisk and/or misconfigured Asterisk).
If you are trying to connect your PC or home network in the SPA LAN port (using it as a router as well as an SPA) I have two words for you:
*DO NOT*I don't think the SPA has the CPU power to handle routing and voice calls simultaneously. Get a secondary IP address from your ISP (preferably) or place the SPA box behind a NAT router.
-Ramon
I meant:
"using it as a router as well as an ATA".
-RFH
