So I could use a cisco 7900 model as well? What settings would I have to adjust in it when I get the softphone account? Also, what packets should I see on the analyzer for my ATA device? RTP packets to the Vonage SIP server? Call setup? Is there keepalvie packets or anything to the ATA device from vonage?
Yes, you can use an IP phone with a Vonage softphone account. I use a Grandstream Budge Tone 101.
As the previous poster said, however, you will need to have a main account set up (making use of Vonage configured hardware), in order to get a softphone account.
IP Phone ConfigurationGrandstream IP Phone Configuration
MAC Address: Product Model: BT100 Software Version: Program--1.0.5.3 Bootloader--1.0.0.18 HTML--1.0.0.36 VOC--1.0.0.6 Custom Ring Tone: ring1--1.0.0.0 ring2--1.0.0.0 ring3--0.0.0.0
Admin Password: IP Address: dynamically assigned via DHCP
SIP Server: sphone.vopr.vonage.net:5060 Outbound Proxy: sphone.vopr.vonage.net:5061 SIP User ID: vonage number Authenticate User ID: vonage number Authenticate Password: ***** Name: (optional, e.g., John Doe)
Advanced Options: Preferred Vocoder: (in listed order) choice 1: current setting is "G722" choice 2: current setting is "PCMU" choice 3: current setting is "PCMA" choice 4: current setting is "G723" choice 5: current setting is "G729" choice 6: current setting is "G726-32" choice 7: current setting is "G728" choice 8: current setting is "PCMU"
Use DNS SRV: No User ID is phone number: Yes SIP Registration: Yes Unregister On Reboot: No Register Expiration: 60 Early Dial: No Dial Plan Prefix: No Key Entry Timeout: 4 Use # as Dial Key: Yes (if set to Yes, "#" will function as the "(Re-)Dial" key) local SIP port: 5060 local RTP port: 5004 Use random port: Yes NAT Traversal: Yes STUN server is: keep-alive interval: 20 seconds Use NAT IP: TFTP Server: (for remote software upgrade and configuration) Voice Mail UserID: SUBSCRIBE for MWI: No, do not send SUBSCRIBE for Message Waiting Indication Auto Answer: No Offhook Auto-Dial: Enable Call Features: No Disable Call-Waiting: No Send DTMF: in-audio DTMF Payload Type: 101 Send Flash Event: No NTP Server: time.nist.gov Time Zone: Date Display Format: Year-Month-Day Daylight Savings Time: Yes Default Ring Tone: system ring tone Send Anonymous: No
