H.323-ID used by Cisco CallManager
Hello,
I'm using Cisco CallManager v 4.1, and I have noted a strange behaviour in the H.323-ID used. I have an H.225 Trunk (Gatekepeer Controlled). Under this menu I give a name to the "Device Name" Field. For example, I call this field "CCM". In the AGK table, the H.323-ID associated to CCM (visbile with show gatekeeper endpoint) is slightly different: for example, "CCM_3". What value does the CCM use to register in the RRQ ? Is there a connection with CTI ID?
Second question: when I have a calling from the CCM, normally in the Setup message the source H.323 is equal to the E.164 number of the calling device.
I also need to exactly understand how CCM creates the H323-ID put in
outgoing SETUP messages. I would like the ongoing Setup to have the same H323-ID used in the RRQ. Does anyone know how to manage it ?
Thank you Alessandro
ango
