Dear Friends:
Want to setup VOIP company, a business under your own brand name? We have complete solution to launche VOIP (VOice Over Internet Protocol) company. All support comes included.
Softswitch is the main element of the platform, which merges the functionality of the following VOIP architecture?s elements.
H323 switch
H323 gatekeeper
SIP Proxy
SIP registrar
Each of the described elements can operate simultaneously with the others. Moreover, the clients, regardless of the protocol, or the way they transfer connections, can connect between one another. This option allows connecting the networks, which because of the differences in implemented protocols or dialects inside the particular protocol, cannot directly transfer connection between one another. Implementing Solution4VOIP as a central traffic controller also introduces a number of additional management, supervision and network security facilitations.
The main characteristics of the softswitch include:
· Simultaneous and transparent support of SIP and H323 protocols (sip?h323 and h323?sip translator · Possibility of implementing various types of proxy (e.g. RTP-proxy or signaling proxy), possibility of choosing proxy for each prefix defined in dialing plan. · Advanced routing and rating system · Full internetworking with most commercially available switches, softswitches, session border controllers and VOIP gateways. · VOIP equipment support · NAT support both for SIP and h323 equipment · Calling to sip devices behind NAT (without the necessity of configuring NAT) · Calling among users registered to softswitch, support for dynamic IP addresses · Authentication of VOIP equipmento by IP address
o by ANI
o by h323id
o by the pair of login/password (according to the SIP standard)
· Flexible routing · Individual, integrated billing system · Managing pre-paid and post-paid accounts · Setting up users in the VSConfig program · Managing users, blocking, setting limits · Generating the groups of users and managing lots · Creating and managing tariffs, the possibility of attributing a tariff to an individual user · Data stored in the MSSQL or MySQL database · Graphic management interface (presentation of the statistical data, billing information, managing clients? accounts, generating PIN, managing the tariffs, dialing plan and others) · Graphic interface presenting the current traffic in the real time, number of the logged in clients, with the division into different types of services, presentation of logs and others · Web interface for clients ? presentation of the connections history, possibility of exporting to the file, presentation of the current account status, possibility of making payments online and others · Easy to set up architecture · Automatic software re-start facilities in case of system failure · Scalability for new telecommunication services by enabling additional modulesAdvantages of managing the system:
· Simplify the management processes and network configuration changes of VoIP equipment · Unify equipment supporting different protocols (or dialects of one protocol) · Manage concentration and routing processes of VoIP traffic · Centralize authorization and billing tasks of VoIP calls in one point · Hide the network structure from third parties, if necessary · Utilize possibility of implementing value-added services such as: calling card and DID calling card system, IPPBX, SMS/ANI/PIN/DID callback system.STANDARD APPLICATIONS
Central point of your VOIP network
Main benefits:
Management of authorization rules of VoIP-gateways
Setting up call routing rules
Provisioning of compatibility for H323 and SIP- equipment of various vendors
Security and load planning of VoIP-traffic by using optional RTP-proxying
Access to the statistical data (ASR, PDD and others)
Transparent interface of the billing system
Network security
When using RTP-proxying SoftSwitch provides a single entry point for VoIP traffic.Both for clients and carriers there is only one IP address available.
Integration of equipment with support of different protocols
One of the most important features of RSF1000 is its ability to support widely accepted signaling IP-protocols - SIP and H323. The system provides transparent converging of one protocol into another, thus allowing performing calls from one type of equipment to another.
SCALABILITY
Through launching subsequent modules, it is very convenient for a provider to extend the range of services offered. Available modules:
IVR for calling cards
Web/SMS/ANI callback (with IVR)
Reseller?s module
Online shop
CallShop
SPECIFICATIONS
Supported protocols
1 H.323 v.2 (H.245 v7, H225 v4) with/without FAST START2 SIP (RFC 3261)
3 proxying of RTP/RTCP streams4 Signalling proxy
5 Support of T38 (SIP, H323)6 Transparent conversion of SIP to H323 and vice versa
Support of the Devices Behind the NAT
1 SIP-devices2 H323-devices
Authentication
1 by IP address ? SIP and H3232 by H323ID ? h323 terminals/gateways
3 by ANI (calling party number) ? SIP and H3234 by login and password- SIP equipment
5 by login and password ? HearLink pc to phone/web to phone dialer (included in the package)6 gatekeeper registration based on aliases
Intelligent routing
1 based on prefixes (the possibility of defining prefixes differentiating individual users)2 based on accessibility of the VOIP gateway
3 based on priorities when choosing a gateway4 depending on available voice codecs
5 depending on prefixes specified in the tariff of an individual clientPhone Numbers Translation
1 Deletion of the set number of digits from the called party number2 Addition of the set number of digits to the called party number
3 Deletion of the set number of digits from the caller number4 Addition of the set number of digits to the caller number
5 Virtual prefixes (for differentiation of the dialing plans)Information for the Billing System
1 Real-time, built in billing system2 Storage in SQL database (MSSQL or MYSQL)
3 pre-paid and post-paid accounts4 Payments history
5 CDR ? examining the logs of the calls carried out from the VSCConfig level, possibility of filtering data according to the set parameters, possibility of exporting data to the file (html, excel, txt, or csv type), presenting the CDR on the WWW pages available for clientsSystem Management and Control Features
1 Graphic User Interface for managing the overall functionality of the system2 Visual presentation of current connections along with the information on their status
3 The number of statistical data presenting the information on the traffic intensity with its various parameters e.g. ASR, PDD. Possibility of limiting the number of data presented by using available filters e.g. only incoming traffic from the particular client, traffic directed to the particular gateway, or prefix etc.4 Visual presentation of logged in clients and their current status, with the division into types of services e.g. gatekeeper users, SIP users, pc2phone, callback.
Operating Systems
1 Windows 2000, 2003, XP------------------------------------------------------------ -----
Contact us if you are interested.
Thank you, Solution4voip.com VOIP Solution Provider Solution for Voice Over Internet Protocol (VOIP)
Email: salesATsolution4voipDOTcom MSN: SalesATsolution4voipDOTcom, SupportATsolution4voipDOTcom Phone: +1 888 8679193
