At work there's a Cisco callmanager server. I connect from home to work using VPN. I have a Cisco ip phone at home. When my VPN is up, I can call anybody at work. They can hear me, but I cannot hear them. If I'm correct, ip phones talk to each other directly after a call is set up. I suspect my client side is blocking incoming ip traffic which tries to initiate a connection to my ip phone.
LAN at work: 192.168.1.x LAN at home: 192.168.20.x (wireless) Ip phone is directly connected to my computer on a separate subnet at.
192.168.21.4 VPN client ip: 192.168.1.32ICS is turned on, on my VPN interface. IP routing in Windows XP is enabled. Windows Firewall is off. Gateway 192.168.1.1 at work has a static route (send 192.168.21.4 to
192.168.1.32). I somehow need to allow connections coming from my VPN interface to the 192.168.21.x subnet. Can this be done?thanks. Arne
