Hello,
I am trying to connect an Asterisk PBX to a Nortel TX-1 using a Cisco 2,811 as a gateway. It is working but no names are exchanged. From the debug mode I see that the Cisco sends the display name (which does not appear on the Nortel's phones) and the Nortel does not bother to send it at all.
I recall that when I had a pilot with Cisco CCM two years ago we had to set the siganlling to ESGF on the Nortel and use MGCP on Cisco (since MGCP protocol forces the Cisco to use ESGF signalling). We could not use H.323 as it forces the Cisco to use ISGF. I suspect that SIP is the same, but setting ISGF signalling on Nortel doesn't help.
Anyone had some luck with this configuration?
Thanks, __Yehavi:
