Je cherche a connecter un as5350 à mon cisco call manager. Le hic, c'est qu'à priori ma version d'ios n'est pas bonne (c5350-js-mz.123-6c.bin). Quel Ios faut-il ?
Merci
Merci
Hello, MGCP to CallManager support for AS5350 is
Featureset IP Plus
12.3(4)T3 c5350-is-mz.12.3-4.T312.3(6) c5350-is-mz.12.3-6 is also shown.
What version of CallManager do you have ?.
Regards, Steve
Hello,
Thank you for your answer. Cisco CallManager version 4.1 I'm trying this version c5350-js-mz.123-8.T3.bin But i'm not sure for my config. With cisco example, i must have this command ccm-manager But this command don't exist, where can i find some example to connect as5350 to CCM4.1 ?
Regards Fabien
Steve McKee wrote:
Hello, Looking at the following URL :
Sure enough, when I look at my 4.0 CM server, I don't see the AS5350 listed as an MCGP Gateway and I don't see it listed under 4.1 documentation.
I think you may have to go with H.323 !.
Regards, Steve
Hi Steve,
Can I send you an e-mail? My e-mail address snipped-for-privacy@voila.fr
Regards, Fabien Steve McKee wrote:
Hi steve,
Sorry,
Thank you for you help. I'm novice and I don't the way to resolve my problem. You have the as5350 configuration, network diagram and ccm configuration. If you could look if I forgot something or if I were mistaken.
@ip as5350 192.168.1.5 @ip pix 192.168.1.1 @ip ccm 192.168.1.2 (static)
============== CONF OF CCM4.1 ============== Route Patterns ============== Route Pattern* 9.@ Partition < None >
Description Numbering Plan* North American Numbering Plan Route Filter < None >
MLPP Precedence Default Gateway or Route List* 192.168.1.2 (Edit)
Gateway Configuration ===================== Product : H.323 Gateway Gateway : 192.168.1.2 Device Protocol: H.225 Registration: Unknown IP Address: 192.168.0.5
Device Information Device Name* 192.168.1.2 Description as5350 Device Pool* Default Call Classification* Use System Default Media Resource Group List < None >
Location < None >
AAR Group < None >
Signaling Port* 1720
Media Termination Point Required
X Retry Video Call as Audio
X Wait for Far End H.245 Terminal Capability Set
Multilevel Precendence and Preemption (MLPP) Information MLPP Domain (e.g., "0000FF") MLPP Indication Not available on this device MLPP Preemption Not available on this device
Call Routing Information Inbound Calls Significant Digits* All Calling Search Space < None >
AAR Calling Search Space < None >
Prefix DN Redirecting Number IE Delivery - Inbound
Enable Inbound FastStart
Outbound Calls Calling Party Selection* Originator Calling Party Presentation* Default Called party IE number type Cisco CallManager Calling party IE number type Cisco CallManager Called Numbering Plan* Cisco CallManager Calling Numbering Plan* Cisco CallManager Caller ID DN X Display IE Delivery
Redirecting Number IE Delivery - Outbound
Enable Outbound FastStart
Codec For Outbound FastStart* G711 a-law 64K
============== Conf of AS5350 ============== ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname AS5350-Viapass ! boot-start-marker boot system flash c5350-is-mz.123-4.T3.bin no boot startup-test boot-end-marker ! ! ! ! resource-pool disable spe default-firmware spe-firmware-1 no aaa new-model ip subnet-zero ip cef ! ! isdn switch-type primary-ni ! ! voice service voip fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco h323 h245 caps mode restricted ! ! ! ! ! ! ! ! ! ! ! fax interface-type fax-mail ! ! ! controller E1 3/0 framing NO-CRC4 pri-group timeslots 1-31 ! controller E1 3/1 framing NO-CRC4 pri-group timeslots 1-13,15-31 ! ! interface FastEthernet0/0 ip address 192.168.1.5 255.255.255.0 duplex auto speed auto ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface Serial0/0 no ip address shutdown clockrate 2000000 ! interface Serial0/1 no ip address shutdown clockrate 2000000 ! interface Serial3/0:15 no ip address isdn switch-type primary-net5 isdn incoming-voice data 64 isdn send-alerting isdn sending-complete no cdp enable ! interface Serial3/1:15 no ip address isdn switch-type primary-net5 isdn T310 4000 no cdp enable ! interface Async1/00 no ip address ##to interface Async1/59 no ip address ! interface Group-Async0 no ip address no group-range ! ip classless ip route 0.0.0.0 0.0.0.0 192.168.1.1 no ip http server ! ! ! ! map-class dialer test dialer voice-call ! ! ! control-plane ! ! ! voice-port 3/0:D connection plar 9000 ! voice-port 3/1:D ! no mgcp timer receive-rtcp no mgcp explicit hookstate ! ! dial-peer voice 100 voip destination-pattern .T session target ipv4:192.168.0.5 incoming called-number 1234 dtmf-relay h245-alphanumeric codec g711alaw ! dial-peer voice 1 pots destination-pattern 9T direct-inward-dial port 3/0:D ! ! ss7 mtp2-variant Bellcore 0 ss7 mtp2-variant Bellcore 1 ss7 mtp2-variant Bellcore 2 ss7 mtp2-variant Bellcore 3 ! line con 0 line aux 0 line vty 0 4 login line 1/00 1/59 no flush-at-activation modem InOut ! scheduler allocate 10000 400 ntp clock-period 17180021 ntp server 64.112.189.11
Thank you, regards, Fabien anonyme wrote:
Hi there, Looking at your config, shouldn't your Route Pattern (Anything starting with a '9') point to 192.168.1.5 (the Gateway) ?. Incoming calls to the Gateway need a Dial Peer pointing back to the CallManager 192.168.1.2.
Anyway, here are some good examples for you :
Regards, Steve
Thank you Steve,
Now I can make outgoing call. But the incoming call on PSTN doesn't work. I have this message :
*Jan 1 03:59:43.053: ISDN Se3/0:15 Q931: RX RELEASE_COMP pd = 8 callref = 0x809C Cause i = 0x80D8 - Incompatible destinationRegards, Fabien
Steve McKee wrote:
