Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Vincent Delporte on November 21, 2006, 5:58 pm
Please log in for more thread options Hi A friend of mine would like to use VoIP applications like Skype or X-Lite without being stuck in front of her computer. She wants something that would let her get further than the Bluetooth solutions typically alow (typically 6-10 feet, which is not far enough). Anybody knows of a solution? Some kind of DECT-based USB key? Thank you. | |||||||||||||||||||||||||||||||
Posted by Jonathan Roberts on November 21, 2006, 6:10 pm
Please log in for more thread options Vincent Delporte wrote: I don't have the answer but I get more than 6-10 feet out of my bt headset. It is a Motorola Hxxx series if that helps. Jonathan | |||||||||||||||||||||||||||||||
Posted by Vincent Delporte on November 22, 2006, 9:53 am
On Tue, 21 Nov 2006 17:10:30 -0600, Jonathan Roberts >I don't have the answer but I get more than 6-10 feet out of my bt
>headset. It is a Motorola Hxxx series if that helps. Thanks for the pointer. The 6-10 feet thing is what I read in sales brochures, hence my looking at a longer-range solution. So you got a H500 and the PC850 USB add-on to use Skype wirelessly? http://direct.motorola.com/ens/bluetooth/data.html | |||||||||||||||||||||||||||||||
Posted by Martin² on November 21, 2006, 8:23 pm
There are some Skype enabled DECT phones, Olympia is one make I recall. If she has got a router with ethernet port then an SIP based VoIP is better solution. Just get an ATA and any DECT phone, and it will work without the computer being on or even connected. Regards, Martin | |||||||||||||||||||||||||||||||
Posted by Vincent Delporte on November 22, 2006, 9:58 am
>solution. Just get an ATA and any DECT phone, and it will work without the >computer being on or even connected. Mmm... So it would look like this: router -> ATA -> DECT base with
Motorola's ear-plug + USB combo at $99, but it's probably more
RJ11 -> DECT headset. Looks like an interesting alternative to expensive too. | |||||||||||||||||||||||||||||||
Wireless headset for VoIP?
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Thank you.
