Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Vincent Delporte on July 21, 2006, 11:34 am
Please log in for more thread options Hello As the list below is long and not always up to date, could someone recommend some VoIP gateways besides the well-know Linksys SPA-3102 and its older brother Sipura SPA-3000? http://www.voip-info.org/wiki/index.php?page=VOIP+Gateways Preferably, I'd like one that has been localized as I read that the POTS is a bit country-specific (impedance, caller ID, ring signal, etc.; FWIW, I intend to use it in France)? Thank you. | ||||||||||||||||||||||
Posted by Jonathan Roberts on July 21, 2006, 9:12 pm
Please log in for more thread options Do you have any special requirements? Multiple providers perhaps? If you need just a vanilla ATA, I would suggest a Sipura 1000/1001. | ||||||||||||||||||||||
Posted by Ivor Jones on July 22, 2006, 3:52 am
[snip] > > Preferably, I'd like one that has been localized as I
> > read that the POTS is a bit country-specific > > (impedance, caller ID, ring signal, etc.; FWIW, I > > intend to use it in France)? >
> Do you have any special requirements? Multiple providers > perhaps? If you need just a vanilla ATA, I would suggest > a Sipura 1000/1001. I'd go for the 2000/2002 as they have two separate phone sockets. The Sipura range also have the distinct advantage over most in that almost everything is configurable, including port impedance, ring voltage, dial/ring tones etc. The downside is that with so many options you really need to know what you're doing or it's easy to mess things up..! Ivor | ||||||||||||||||||||||
Posted by Vincent Delporte on July 22, 2006, 4:53 am
On Sat, 22 Jul 2006 08:52:31 +0100, "Ivor Jones" >> Do you have any special requirements? Multiple providers
>> perhaps? If you need just a vanilla ATA, I would suggest >> a Sipura 1000/1001. >
>I'd go for the 2000/2002 as they have two separate phone sockets. Sorry guys. I didn't mean an ATA (ie. a box to turn analog equipments like handsets and fax machines into SIP-fluent devices), but an FXO-to-SIP adapter like the Sipura 3000 or the Linksys 3102. I keep seeing those two mentionned, but are there other brands/models I should consider, especially some that have been localized to match differences in POTS characteristics (so I don't end up shelling out 200E on a box that just doesn't work reliably outside the US)? Thank you. | ||||||||||||||||||||||
| Similar Threads | Posted |
| Which VoIP gateway? | July 21, 2006, 11:34 am |
| Linux VoIP Gateway | July 13, 2004, 9:28 pm |
| BRI VoIP Gateway with MGCP | February 15, 2005, 7:34 pm |
| VoIP Gateway Identification | March 25, 2005, 11:57 am |
| VoIP Gateway with Answerphone | June 15, 2005, 7:29 am |
| Comtrend CM-801 VoIP Gateway | July 24, 2005, 12:27 am |
| VoIP: Voice Gateway | August 13, 2005, 11:47 am |
| VoIP: Voice Gateway | August 16, 2005, 12:42 pm |
| VoIP: Voice Gateway | August 19, 2005, 1:29 pm |
| VoIP phones and Gateway | August 30, 2005, 8:02 am |
| VoIP media gateway | November 28, 2005, 9:59 am |
| VoIP & GSM gateway from Portech | April 25, 2008, 5:20 am |
| VoIP & GSM gateway from PORTech | April 25, 2008, 5:25 am |
| VoIP - PRI between Definity G3 and 2611 Gateway | November 30, 2004, 2:09 pm |
Which VoIP gateway?
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Thank you.
