Voice-Over-IP VoIP newbie seeks advice!
Subject Author Date
VoIP newbie seeks advice! Adam 04-14-05
Posted by Adam on April 14, 2005, 3:57 pm
Hello,
I've just bought a Sipura SPA 3000 after having a play around with XLite and
being quite happy with VoIP (using 1899.com).
However, when I make a call over VoIP, the person I'm calling can hear me,
but I can't hear them.
From looking around the web, it sounds like this is a common problem when a
hardware VoIP device is behind an NAT (as mine is). However, I haven't
really found a solution in works of one syllable! (I really am very new at
this whole VoIP thing).
My internet connection is via a cable modem (2Mb down, 512Kb up), and the
cable modem is plugged into a Linksys BEFSR41 router. My SPA 3000 is
plugged into one of the ports on this router.
I've heard that a STUN server should be able to get around NAT problems, but
although I've set a STUN server in the SPA config, I still get the same
problem.
My router supports uPnP, which, again, I understand should make things
easier! (I also know very little about uPnP I'm afraid!).
I get the same problem with a couple of different SIPs I've tried.
Does anyone have any ideas? Am I correct in thinking it's a NAT problem?
Is it worth me putting the SPA in the DMZ and see if that works? Otherwise,
do I need to forward any ports to the SPA? (although I thought STUN and/or
uPnP got around this problem!).
Help!
A.
Posted by Kyler Laird on April 14, 2005, 8:08 pm
I've set "Insert VIA rport" and "Send Resp To Src Port" to "yes" (SIP -> NAT
Support Parameters). That's gotten it working through NAT for me.
--kyler
Posted by Ivor Jones on April 14, 2005, 11:56 pm
Adam wrote:
[snip]
> problems, but although I've set a STUN server in the SPA config, I
> still get the same problem.
What port have you set for the STUN server..?
> things easier! (I also know very little about uPnP I'm afraid!).
Same here, but my router doesn't support it so can't say..!
SIPs..?
> problem? Is it worth me putting the SPA in the DMZ and see if that
> works? Otherwise, do I need to forward any ports to the SPA?
> (although I thought STUN and/or uPnP got around this problem!).
Yes, try it, definitely. My SPA-2000 seems to require this on Sipgate.
*In addition* try forwarding ports 5004-5005, 5060-5061, 8000-8019 plus
whatever port the STUN server wants. Default is 3478 although Sipgate uses
10000.
Ivor
Similar ThreadsPosted
VoIP newbie seeks advice! April 14, 2005, 3:57 pm
voip newbie seeks help August 9, 2007, 2:44 pm
VONAGE Newbie w/newbie question August 11, 2007, 9:40 am
Residential VOIP newbie questions August 12, 2004, 1:07 pm
Newbie help pls! November 17, 2004, 1:21 am
Newbie March 13, 2005, 12:48 am
newbie March 25, 2005, 12:15 am
Help for a Newbie May 4, 2005, 7:12 am
Newbie Question June 26, 2006, 12:18 am
PLEASE HELP - A newbie question June 30, 2008, 9:51 am
RTP: Newbie General Questions November 27, 2005, 11:09 am
Newbie SIP Server question November 15, 2006, 12:03 pm
Newbie to Asterisk some basic questions May 29, 2008, 5:12 pm
NEWBIE HELP asterisk@home + Broadvoice setup July 11, 2005, 2:20 pm
Voip advice August 3, 2004, 8:35 am
