Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Rob on November 30, 2004, 2:09 pm
Please log in for more thread options I am having trouble getting a PRI up between an Avaya Definity G3 PBX and my 2611 voice gateway. I'm 99% sure I have the correct cable (a T1 crossover cable) as Layer 1 of the PRI is active and port ser1/0:23 shows "up up". My gateway is registered with CallManager just fine, but I'm pretty sure this is simply an ISDN issue. I have the PBX setup as ISDN "user" side and the 2611 as ISDN "network" side. We are using National/NI2. The Definity is configured as Country code 1, Protocol version a. Does anyone know if this is correct? Also, should the "Connect" version on the PBX be "pbx" or "line-side"?? When I do a "show isdn status" the Layer 2 state of "TEI_ASSIGNED" is a problem in my mind - I think this should be "MULTIPLE_FRAME_ESTABLISHED." Thanks - Rob. Gateway1#sho isdn status Global ISDN Switchtype = primary-ni %Q.931 is backhauled to CCM-MANAGER on DSL 0. Layer 3 output may not apply ISDN Serial1/0:23 interface ******* Network side configuration ******* dsl 0, interface ISDN Switchtype = primary-ni L2 Protocol = Q.921 L3 Protocol(s) = CCM-MANAGER Layer 1 Status: ACTIVE Layer 2 Status: TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED Layer 3 Status: 0 Active Layer 3 Call(s) Active dsl 0 CCBs = 0 The Free Channel Mask: 0x807FFFFF Number of L2 Discards = 0, L2 Session ID = 94 Gateway1# Gateway1# Gateway1# Gateway1#sho ip int brief Interface IP-Address OK? Method Status Prot ocol FastEthernet0/0 10.10.4.50 YES NVRAM up up FastEthernet0/1 10.10.5.50 YES NVRAM up up Serial1/0:0 unassigned YES unset down down Serial1/0:1 unassigned YES unset down down Serial1/0:2 unassigned YES unset down down (snip) Serial1/0:21 unassigned YES unset down down Serial1/0:22 unassigned YES unset down down Serial1/0:23 unassigned YES NVRAM up up Gateway1# Gateway1# Gateway1#sho run (some non-relevant config snipped) ! network-clock-participate slot 1 no network-clock-participate wic 0 network-clock-select 1 T1 1/0 network-clock-select 2 T1 1/1 ! isdn switch-type primary-ni voice-card 1 ! ccm-manager redundant-host 10.219.16.1 ccm-manager mgcp ccm-manager music-on-hold ccm-manager config server 10.219.16.1 ccm-manager config ! ! controller T1 1/0 framing esf fdl att linecode b8zs pri-group timeslots 1-24 service mgcp ! interface Serial1/0:23 no ip address isdn switch-type primary-ni isdn protocol-emulate network isdn incoming-voice voice isdn bind-l3 ccm-manager no cdp enable ! voice-port 1/0:23 ! mgcp mgcp call-agent 10.219.17.1 service-type mgcp version 0.1 ! dial-peer voice 1 pots application mgcpapp port 1/0:23 ! | |||||||||||||
Posted by Brian LaVallee on December 3, 2004, 6:28 pm
Please log in for more thread options Brian LaVallee -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Cisco Internetwork Operating System Software IOS (tm) 3600 Software (C3620-IS-M), Version 12.3(1a), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2003 by cisco Systems, Inc. Compiled Thu 05-Jun-03 17:53 by dchih Image text-base: 0x60008950, data-base: 0x6187C000 ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) Router uptime is 10 weeks, 23 hours, 56 minutes System returned to ROM by power-on System image file is "flash:c3620-is-mz.123-1a.bin" cisco 3620 (R4700) processor (revision 0x81) with 59392K/6144K bytes of memory. Processor board ID 25119094 R4700 CPU at 80Mhz, Implementation 33, Rev 1.0 Bridging software. X.25 software, Version 3.0.0. Primary Rate ISDN software, Version 1.1. 1 FastEthernet/IEEE 802.3 interface(s) 1 Channelized T1/PRI port(s) DRAM configuration is 32 bits wide with parity disabled. 29K bytes of non-volatile configuration memory. 16384K bytes of processor board System flash (Read/Write) Configuration register is 0x2102 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Current configuration : 1646 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname Hostname ! boot system flash c3620-is-mz.123-9.bin enable secret 5 xXxXxXxXxXxXxXxXxXxXxXxXxXxXxXxX enable password xXxXxXxX ! voice-card 1 ! ip subnet-zero ! ip name-server NNN.NNN.NNN.NNN ! isdn switch-type primary-ni isdn voice-call-failure 0 ! voice hunt user-busy voice call carrier capacity active ! voice service voip signaling forward unconditional fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none sip ! voice class codec 99 codec preference 1 g711ulaw codec preference 2 g729r8 ! no voice hpi capture buffer no voice hpi capture destination ! controller T1 1/0 framing sf linecode ami ! interface FastEthernet0/0 ip address NNN.NNN.NNN.NNN 255.255.255.240 speed auto full-duplex ! ip http server ip classless ip route 0.0.0.0 0.0.0.0 NNN.NNN.NNN.NNN ! dialer-list 1 protocol ip permit ! dial-peer cor custom ! dial-peer voice 1 voip huntstop preference 2 destination-pattern .T progress_ind setup enable 3 no modem passthrough voice-class codec 99 session protocol sipv2 dtmf-relay rtp-nte no vad ! dial-peer voice 2 pots preference 2 application session destination-pattern .......... translate-outgoing called 300 no digit-strip direct-inward-dial forward-digits all ! sip-ua retry invite 2 retry response 3 retry bye 3 retry prack 6 timers expires 300000 sip-server ipv4:NNN.NNN.NNN.NNN no transport tcp ! line con 0 logging synchronous line aux 0 line vty 0 4 password 7 xXxXxXxXxXxXxX logging synchronous login ! end | |||||||||||||
Posted by mbawa on February 2, 2005, 2:25 am
Please log in for more thread options Hi,
I am planning to inegrate a Definity PBX with a 2611 router .Can you send me the config for Definity and where should I port the PRI on Definity ? Thanks, Mike ------------------------------------- Rob wrote: > Hi,
> and my 2611 voice gateway. I'm 99% sure I have the correct cable (a T1 > crossover cable) as Layer 1 of the PRI is active and port ser1/0:23 > shows "up up". > My gateway is registered with CallManager just fine, but I'm pretty
> sure this is simply an ISDN issue. I have the PBX setup as ISDN > "user" > side and the 2611 as ISDN "network" side. We are using > National/NI2. > The Definity is configured as Country code 1, Protocol version a. Does > anyone know if this is correct? Also, should the "Connect" > version on > the PBX be "pbx" or "line-side"?? > When I do a "show isdn status" the Layer 2 state of
> "TEI_ASSIGNED" is > a problem in my mind - I think this should be > "MULTIPLE_FRAME_ESTABLISHED." > Thanks - Rob.
> Global ISDN Switchtype = primary-ni > %Q.931 is backhauled to CCM-MANAGER on DSL 0. Layer 3 output may not
> apply > ISDN Serial1/0:23 interface
> ******* Network side configuration ******* > dsl 0, interface ISDN Switchtype = primary-ni > L2 Protocol = Q.921 L3 Protocol(s) = CCM-MANAGER > Layer 1 Status: > ACTIVE > Layer 2 Status: > TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED > Layer 3 Status: > 0 Active Layer 3 Call(s) > Active dsl 0 CCBs = 0 > The Free Channel Mask: 0x807FFFFF > Number of L2 Discards = 0, L2 Session ID = 94 > Gateway1# > Gateway1# > Gateway1# > Gateway1#sho ip int brief > Interface IP-Address OK? Method Status > Prot > ocol > FastEthernet0/0 10.10.4.50 YES NVRAM up > up > FastEthernet0/1 10.10.5.50 YES NVRAM up
> up > Serial1/0:0 unassigned YES unset down
> down > Serial1/0:1 unassigned YES unset down
> down > Serial1/0:2 unassigned YES unset down
> down > (snip)
> down > Serial1/0:22 unassigned YES unset down
> down > Serial1/0:23 unassigned YES NVRAM up
> up > Gateway1# > Gateway1# > Gateway1#sho run > (some non-relevant config snipped)
> network-clock-participate slot 1 > no network-clock-participate wic 0 > network-clock-select 1 T1 1/0 > network-clock-select 2 T1 1/1 > ! > isdn switch-type primary-ni > voice-card 1 > ! > ccm-manager redundant-host 10.219.16.1 > ccm-manager mgcp > ccm-manager music-on-hold > ccm-manager config server 10.219.16.1 > ccm-manager config > ! > ! > controller T1 1/0 > framing esf > fdl att > linecode b8zs > pri-group timeslots 1-24 service mgcp > ! > interface Serial1/0:23 > no ip address > isdn switch-type primary-ni > isdn protocol-emulate network > isdn incoming-voice voice > isdn bind-l3 ccm-manager > no cdp enable > ! > voice-port 1/0:23 > ! > mgcp > mgcp call-agent 10.219.17.1 service-type mgcp version 0.1 > ! > dial-peer voice 1 pots > application mgcpapp > port 1/0:23 > ! ##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive http://www.cabling-design.com/forums no-spam read and post WWW interface to your favorite newsgroup - comp.dcom.sys.cisco,comp.dcom.voice-over-ip - messages and counting! ##-----------------------------------------------## | |||||||||||||
| Similar Threads | Posted |
| VoIP - PRI between Definity G3 and 2611 Gateway | November 30, 2004, 2:09 pm |
| VoiceGateway Solution con PBX Avaya Definity | September 17, 2005, 8:08 pm |
| Which VoIP gateway? | July 21, 2006, 11:34 am |
| Linux VoIP Gateway | July 13, 2004, 9:28 pm |
| BRI VoIP Gateway with MGCP | February 15, 2005, 7:34 pm |
| VoIP Gateway Identification | March 25, 2005, 11:57 am |
| VoIP Gateway with Answerphone | June 15, 2005, 7:29 am |
| Comtrend CM-801 VoIP Gateway | July 24, 2005, 12:27 am |
| VoIP: Voice Gateway | August 13, 2005, 11:47 am |
| VoIP: Voice Gateway | August 16, 2005, 12:42 pm |
| VoIP: Voice Gateway | August 19, 2005, 1:29 pm |
| VoIP phones and Gateway | August 30, 2005, 8:02 am |
| VoIP media gateway | November 28, 2005, 9:59 am |
| VoIP & GSM gateway from Portech | April 25, 2008, 5:20 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> shows "up up".
> Thanks - Rob.
> apply
> Layer 1 Status:
> ACTIVE
> Layer 2 Status:
> Layer 3 Status:
> Gateway1#
> Gateway1#
> Gateway1#
> Prot
> ocol
> up
> up
> down
> down
> down
> (snip)
> down
> down
> up
> Gateway1#
> Gateway1#
> Gateway1#sho run
> voice-card 1
> ccm-manager mgcp
> ccm-manager config
> controller T1 1/0
> framing esf
> fdl att
> linecode b8zs
> no ip address
> no cdp enable
> voice-port 1/0:23
> mgcp
> application mgcpapp
> port 1/0:23
