Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on April 25, 2008, 5:20 am
Please log in for more thread options Terminals, E1/T1 GSM Channel Banks, VoIP GSM Gateways and Skype Gateways VOIP GSM GATEWAY For call termination (VoIP to GSM ) and origination (GSM to VoIP). It is SIP based and compatible with Asterisk and SIP Proxy Server: Up to two channels 50 sets routes setting Enable 1-stage dialing, 2-stage dialing All functions can be set on web GSM GATEWAY,GSM FIXED WIRELESS TERMINALS - 1,4,8 PORTS MT-350/MT-354/MT-358 1/4/8 ports GSM Fixed Wireless Terminals (FXS,FXO,GSM) -Cost saving effect- Make call from fixed lines (PBX or PSTN) to GSM networks and From GSM network to fixed lines), and enables up to 1/4/8 simultaneous calls to/from GSM networks. FXS,FXO,GSM interface Dial plan (GSM Prefix No.Setting - 50 sets) Auto-select economic route ( LCR ) Only 1 (MT-350/MT-354) or 2(MT-358) antennas Polarity reversing function Follow me-Call-transfer feature (GSM TO PSTN,PSTN TO GSM): PSTN to GSM - an incoming call of PSTN will be transferred to specify GSM no. GSM to PSTN GSM in PSTN out, give you a prompt "du" and you can enter any destination number and an incoming call of GSM will be transferred to specify PSTN no E1/T1 PRI GSM GATEWAY DMT accepts incoming calls from E1/T1 PRI of PSTN or PBX and chooses one GSM channel to dial out according to the prefix of the destination mobile number. In this way, we can have least cost routing. DMT can provide Call Detail Record (CDR) for traffic and accounting management. ISDN PRI interface: one port GSM interface: 31 ports Optional external SCE-900: expands SIM card upto 32 pieces per GSM channel Optional external SCBox: expands SIM card upto four pieces per GSM channel Applicable for telecom service providers VoIP application: gateway's E1/T1 port connects DMT's E1/T1 port Calling time: user can assign the calling time for each sheet of the SIM card.When the time runs out, system will block this GSM port, or switch to next unused SIM card (in the case that SCE/SCBox is installed) PRI to GSM, GSM to PRI (two-way) Option: SMS Function(Short message Service) Option: DMT-2 : E1*1 in,GSM*31 and E1*1 out Feel free to contact me: jovi@portech.com.tw | ||||||||||
| Similar Threads | Posted |
| VoIP & GSM gateway from Portech | April 25, 2008, 5:20 am |
| VoIP & GSM gateway from PORTech | April 25, 2008, 5:25 am |
| Which VoIP gateway? | July 21, 2006, 11:34 am |
| Linux VoIP Gateway | July 13, 2004, 9:28 pm |
| BRI VoIP Gateway with MGCP | February 15, 2005, 7:34 pm |
| VoIP Gateway Identification | March 25, 2005, 11:57 am |
| VoIP Gateway with Answerphone | June 15, 2005, 7:29 am |
| Comtrend CM-801 VoIP Gateway | July 24, 2005, 12:27 am |
| VoIP: Voice Gateway | August 13, 2005, 11:47 am |
| VoIP: Voice Gateway | August 16, 2005, 12:42 pm |
| VoIP: Voice Gateway | August 19, 2005, 1:29 pm |
| VoIP phones and Gateway | August 30, 2005, 8:02 am |
| VoIP media gateway | November 28, 2005, 9:59 am |
| VoIP - PRI between Definity G3 and 2611 Gateway | November 30, 2004, 2:09 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
