Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Adrian on April 19, 2007, 4:37 pm
Please log in for more thread options Hi All, Does anyone have any experience of using Verizon's VoIP service outside the US? In the light of Vonage's troubles, I am looking at alternative providers. I am particularly concerned that my US numbers should function during periods when I am in the UK. Thanks Adrian | |||||||||||||||||||
Posted by Ivor Jones on April 19, 2007, 8:30 pm
Please log in for more thread options As long as the ISP you're using doesn't block any required ports, I can't see any reason it shouldn't work. Ivor | |||||||||||||||||||
Posted by Adrian on April 20, 2007, 11:14 am
> > > Hi All,
> > service outside the US? >
> > alternative providers. I am particularly concerned that > > my US numbers should function during periods when I am in > > the UK. >
> As long as the ISP you're using doesn't block any required ports, I can't > see any reason it shouldn't work. > > Ivor Thank you for your input Ivor. Your comments are appreciated. Technically I am sure you are correct. The issue that concerns me is as follows: As part of their contract, Verizon insist that whenever the ATA is moved, the user needs to logon and change the physical address for emergency 911 dialing purposes. If they cannot handle 911 calls at the new location Verizon reserve the right to terminate service. Clearly they cannot handle emergency calls if the ATA is in the UK. Now, one could just ignore this requirement. But, I am sure Verizon can determine where the ATA is connected to the internet by the ISP's IP address. So they question is, do they check? And, do they really care? The foregoing explains why I am looking for someone with actual experience of utilizing VoiceWing outside the US. Adrian | |||||||||||||||||||
Posted by fugettaboutit on April 20, 2007, 4:04 pm
Adrian wrote: >>
>> >>> Hi All,
>>> Does anyone have any experience of using Verizon's VoIP >>> service outside the US? >>> In the light of Vonage's troubles, I am looking at >>> alternative providers. I am particularly concerned that >>> my US numbers should function during periods when I am in >>> the UK. >> As long as the ISP you're using doesn't block any required ports, I can't
>> see any reason it shouldn't work. >> >> Ivor >
> Thank you for your input Ivor. Your comments are appreciated. > Technically I am sure you are correct. > > The issue that concerns me is as follows: As part of their contract, > Verizon insist that whenever the ATA is moved, the user needs to logon > and change the physical address for emergency 911 dialing purposes. > If they cannot handle 911 calls at the new location Verizon reserve > the right to terminate service. Clearly they cannot handle emergency > calls if the ATA is in the UK. > > Now, one could just ignore this requirement. But, I am sure Verizon > can determine where the ATA is connected to the internet by the ISP's > IP address. So they question is, do they check? And, do they really > care? > > The foregoing explains why I am looking for someone with actual > experience of utilizing VoiceWing outside the US. > > > Adrian > I have Verizon Voicewing. During my divorce, I lived in another city over 100 miles away. I used a totally different ISP where I was staying. All I did was confirm that I was still at the old address once I arrived at my temporary location. Yes, this is cheating and would be problematic for 911 service, however, I was in an extraordinary circumstance and had many other options available that I would have used for an emergency. | |||||||||||||||||||
Posted by Adrian on April 20, 2007, 4:43 pm
> Adrian wrote:
> > > >>> Hi All,
> >>> Does anyone have any experience of using Verizon's VoIP > >>> service outside the US? > >>> In the light of Vonage's troubles, I am looking at > >>> alternative providers. I am particularly concerned that > >>> my US numbers should function during periods when I am in > >>> the UK. > >> As long as the ISP you're using doesn't block any required ports, I can't > >> see any reason it shouldn't work. >
> >> Ivor
> > Verizon insist that whenever the ATA is moved, the user needs to logon > > and change the physical address for emergency 911 dialing purposes. > > If they cannot handle 911 calls at the new location Verizon reserve > > the right to terminate service. Clearly they cannot handle emergency > > calls if the ATA is in the UK. >
> > can determine where the ATA is connected to the internet by the ISP's > > IP address. So they question is, do they check? And, do they really > > care? >
> > Adrian
quoted text -
> I have Verizon Voicewing. During my divorce, I lived in another city > over 100 miles away. I used a totally different ISP where I was staying. > All I did was confirm that I was still at the old address once I arrived > at my temporary location. Yes, this is cheating and would be problematic > for 911 service, however, I was in an extraordinary circumstance and had > many other options available that I would have used for an emergency.- Hide >
> - Show quoted text - Thank you. This is exactly what I needed to know. I have UK numbers to summon emergency help in the UK! Adrian | |||||||||||||||||||
| Similar Threads | Posted |
| Verizon VoiceWing | April 19, 2007, 4:37 pm |
| Re: Why didn't Verizon sue Cisco instead? | March 11, 2007, 12:10 pm |
| Verizon Sues Vonage in Patents Dispute | June 19, 2006, 4:58 pm |
| Verizon vs. Vonage: The Empire Strikes Back | February 20, 2007, 11:02 am |
Verizon VoiceWing
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> the UK.
