Voice-Over-IP VOIP, The Right Choice?
Subject Author Date
VOIP, The Right Choice? RFleming 08-04-07
Posted by on August 4, 2007, 7:45 am
Hello,
I have been trying to find an answer for several weeks and have had no
luck. I am a software designer, and I am trying to find a solution to
a problem. I would like to send an audio signal, such as "good", or
play a bell for good, or to say "bad" or play a buzzer sound for bad.
I would like to be able to do this over a from one PC to multiple
headsets/headphones. This would not be a "global broadcast", meaning
I may choose to send "good" to headset number 1, but send nothing to
the other headsets. These same headsets would be wireless. My range
is about 15-30 feet. What I can't seem to find is a device to do
this. I don't care if it is a small battery powered "black box" that
I can send audio to and plug a headset into, or if it is an actual
headphone that allows you to communicate to it via TCPIP. Does such
an item exist?
Posted by fugettaboutit on August 4, 2007, 8:29 am
It sounds like you need to utilize multicast so you can communicate with
a select set of receivers (multicast groups). I also assume you run a
VoIP environment? If so, take a look at this link...don't know if it's
exactly what you need, but it might get you closer:
http://www.twistpair.com/index/webapp-knowledgebase-action?articleid=80
Good luck!
RFleming@NationalSteel.com wrote:
> Hello,
> an item exist?
Posted by GeekBoy on August 6, 2007, 10:20 pm
Multicast will not work until TCP/IP v6 is implemented.
> a select set of receivers (multicast groups). I also assume you run a VoIP
> environment? If so, take a look at this link...don't know if it's exactly
> Good luck!
>> Hello,
>> an item exist?
Posted by fugettaboutit on August 7, 2007, 7:36 am
That is not correct, as multicast is certainly not limited to IPv6. I
use multicast in my IPv4 net for music-on-hold services enterprise-wide,
both LAN and WAN subnets. Over a thousand devices are configured as
multicast groups.
Also, Berbee produced a product that streamed multicast audio streams to
existing 7900 series IP phones. It was their product, but I believe
there are others out there. Again, IPv6 is not a determining factor for
multicast operation.
Similar ThreadsPosted
VOIP, The Right Choice? August 4, 2007, 7:45 am
Choice between Aastra and Cisco for asterisk January 25, 2007, 4:31 pm
Voip Updated Howto,New Voip Phones,Voip Conferencing,Satellite Voip,Virtual PBX Solutions May 21, 2006, 11:18 am
Voip at Home,Voip Updated Howto,New Voip Phones,Voip Conferencing, May 26, 2006, 9:42 am
VoIP Products, VoIP Solutions, VoIP Services (www.doretel.co September 2, 2005, 7:01 pm
VOIP providers better if closer to your area? Recommendation on VOIP provider with BYOD device or not... March 9, 2008, 10:13 pm
Any VoIP phone will work with any VoIP software (skype, Gizmo, VoipBuster,etc) December 11, 2005, 5:47 pm
VOIP Phone Service - Basics, Tutorial, VOIP Technology, Info. All in One April 16, 2006, 12:40 pm
Voip Over High Speed Internet Access,Voip Updated Howto, June 28, 2006, 9:18 pm
To VOIP Provider: opportunity to expand your VOIP service to China December 11, 2005, 10:46 pm
To VOIP Provider: opportunity to expand your VOIP service to China December 11, 2005, 10:47 pm
Hosted VoIP Billing Solution for Global VoIP Companies March 21, 2006, 1:54 pm
Voip Updated Basic,Translating,Voip News and Advanced April 27, 2006, 8:43 pm
voip to voip calls March 12, 2005, 1:48 am
Latest voip phone/usb phone/voip gateway February 28, 2006, 3:54 am
