Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on January 8, 2006, 5:29 pm
Please log in for more thread options I've just signed-up with Sunrocket (too early to give an accurate opinion, but so far no problems (knock wood!)) and would like to eventually use the existing house wiring. As a simple test, I expected the "gizmo" (what sunrocket calls the device) would work if I plug two separate phones into the single gizmo jack using a dual phone jack adapter. But both phones didn't work! If I unplug either one of them from the adapter, the other single connected phone works. The reason I'm testing in this way is because I ultimately would like to use the existing house wiring (yes I know I would need to make sure the house wiring is no longer connected to the land-based provider). So I thought a simple test like I described above would work. Note: I know the dual jack adapter is working fine, as well both phones because I'm still able to test this configuration on my landline phone (landline service hasn't been cancelled yet). All I'm basically doing is "splitting" the phone line connected to the gizmo and attaching two separate phones, and expecting both phones to work. What am I missing here in my assumption ?????? I should mention, but it shouldn't matter, that one of the phones I'm using is the expandable type. I'll ty using two regular phones. | |||||||||||||
Posted by Moe on January 12, 2006, 7:04 am
Please log in for more thread options cpurvis3@csc.com wrote: jumped it to the house phone wiring (of course unhooked the landline from the box first) and it is working OK that way. I have two phones and a recorder on the lines. I like the old manual recorder better then a voice mail box which is also available. One glance at the recorder and I know if I've gotten a call. I use a cable modem and two or three computers plus the phone through a router. I was having problems the other day and changed the router with a cheap one from wal-mart to help trouble shoot the problem. The voip was not usable using the new router but when I plugged the sipura directly to the phone box it worked fine so the cable slow or the new (cheap) router can't handle the load. testing to be done. | |||||||||||||
Posted by Marc Popek on February 9, 2006, 8:47 pm
If you want to maintain two lie phone use, say voip and pstn, and combine these lines onto a single telephone handset or other telco equipment,,,you may want to consider the Combine a line device. Marco http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5863619866&rd=1&sspagenam e=STRK%3AMESE%3AIT&rd=1 > I've just signed-up with Sunrocket (too early to give an accurate
> opinion, but so far no problems (knock wood!)) and would like to > eventually use the existing house wiring. > > As a simple test, I expected the "gizmo" (what sunrocket calls the > device) would work if I plug two separate phones into the single gizmo > jack using a dual phone jack adapter. But both phones didn't work! If > I unplug either one of them from the adapter, the other single > connected phone works. > > The reason I'm testing in this way is because I ultimately would like > to use the existing house wiring (yes I know I would need to make sure > the house wiring is no longer connected to the land-based provider). > So I thought a simple test like I described above would work. > > Note: I know the dual jack adapter is working fine, as well both phones > because I'm still able to test this configuration on my landline phone > (landline service hasn't been cancelled yet). > > All I'm basically doing is "splitting" the phone line connected to the > gizmo and attaching two separate phones, and expecting both phones to > work. What am I missing here in my assumption ?????? > I should mention, but it shouldn't matter, that one of the phones I'm > using is the expandable type. I'll ty using two regular phones. > | |||||||||||||
Posted by Marc Popek on February 14, 2006, 2:34 pm
Moved here http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5866340536&rd=1&sspagenam e=STRK%3AMESE%3AIT&rd=1 Thanks for the continued support and questions. Supplies are limited.. > If you want to maintain two lie phone use, say voip and pstn, and combine
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5863619866&rd=1&sspagenam > these lines onto a single telephone handset or other telco equipment,,,you > may want to consider the Combine a line device. > > Marco > > > e=STRK%3AMESE%3AIT&rd=1
> > opinion, but so far no problems (knock wood!)) and would like to > > eventually use the existing house wiring. > > > > As a simple test, I expected the "gizmo" (what sunrocket calls the > > device) would work if I plug two separate phones into the single gizmo > > jack using a dual phone jack adapter. But both phones didn't work! If > > I unplug either one of them from the adapter, the other single > > connected phone works. > > > > The reason I'm testing in this way is because I ultimately would like > > to use the existing house wiring (yes I know I would need to make sure > > the house wiring is no longer connected to the land-based provider). > > So I thought a simple test like I described above would work. > > > > Note: I know the dual jack adapter is working fine, as well both phones > > because I'm still able to test this configuration on my landline phone > > (landline service hasn't been cancelled yet). > > > > All I'm basically doing is "splitting" the phone line connected to the > > gizmo and attaching two separate phones, and expecting both phones to > > work. What am I missing here in my assumption ?????? > > I should mention, but it shouldn't matter, that one of the phones I'm > > using is the expandable type. I'll ty using two regular phones. > > >
Posted by Marc Popek on February 21, 2006, 8:06 pm
and here Marc http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5869416579&rd=1&sspagenam e=STRK%3AMESE%3AIT&rd=1 >
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5866340536&rd=1&sspagenam > > Moved here > > > e=STRK%3AMESE%3AIT&rd=1
> > Thanks for the continued support and questions. Supplies are limited.. > > > If you want to maintain two lie phone use, say voip and pstn, and
combine
equipment,,,you
> > > > Marco > > > > >
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5863619866&rd=1&sspagenam > > e=STRK%3AMESE%3AIT&rd=1
phones
> > > opinion, but so far no problems (knock wood!)) and would like to > > > eventually use the existing house wiring. > > > > > > As a simple test, I expected the "gizmo" (what sunrocket calls the > > > device) would work if I plug two separate phones into the single gizmo > > > jack using a dual phone jack adapter. But both phones didn't work! If > > > I unplug either one of them from the adapter, the other single > > > connected phone works. > > > > > > The reason I'm testing in this way is because I ultimately would like > > > to use the existing house wiring (yes I know I would need to make sure > > > the house wiring is no longer connected to the land-based provider). > > > So I thought a simple test like I described above would work. > > > > > > Note: I know the dual jack adapter is working fine, as well both > > > because I'm still able to test this configuration on my landline phone
> > > (landline service hasn't been cancelled yet). > > > > > > All I'm basically doing is "splitting" the phone line connected to the > > > gizmo and attaching two separate phones, and expecting both phones to > > > work. What am I missing here in my assumption ?????? > > > I should mention, but it shouldn't matter, that one of the phones I'm > > > using is the expandable type. I'll ty using two regular phones. > > > > >
| Similar Threads | Posted |
| Testing: Hooking Two Phones to the VOLP Gizmo | January 8, 2006, 5:29 pm |
| Gizmo Rates? | June 26, 2006, 9:40 pm |
| Voice Qulaity Testing | October 14, 2004, 1:16 pm |
| A SIP Server needed for testing | October 20, 2004, 6:35 am |
| Testing a new setup - Zoom X5V | December 18, 2004, 8:52 pm |
| Testing Voice Codec | May 4, 2005, 12:24 am |
| has someone experience in testing SIP UA on SFTF | August 23, 2006, 11:05 pm |
| Please call me for SIP testing on 446714@fwd.pulver.com | September 22, 2004, 5:22 pm |
| testing dial up modem over VoIP | December 3, 2004, 6:21 pm |
| Sunrocket gizmo port forwarding | May 7, 2005, 9:51 pm |
| Video phone testing tool | December 16, 2005, 2:26 am |
| Gizmo offering FREE SMS to over 60 countries | March 10, 2007, 9:42 am |
| Urgent Opening for VOIP - Testing | March 12, 2008, 5:50 am |
| Tools for testing & monitoring MGCP networks? | August 25, 2004, 8:01 am |
| Push To Talk Server needed for testing | December 6, 2004, 10:48 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
