Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on April 16, 2005, 7:51 pm
Hi All, How can I setup a very simple VOIP network between two offices. Both offices have broadband and I am looking to setup just one line between the offices. What hardware would I require for this ? thanks anand | ||||||||||||||||||||||||||||||||||
Posted by BlueRinse on April 17, 2005, 11:57 am
Please log in for more thread options On Sat, 16 Apr 2005 16:51:11 -0700, anandsekar wrote: How many phones? Existing pbx at one or both? The simplest example would be two PC running linux and asterisk For the phones, each PC used with 1 or more ATA to connect 1 or 2 regular phones per unit 1 or more PC card FXS interfaces to connect 1 phone per interface 1 or more SIP phones all of which would connect on the LAN ATA are around $80-$120 A card with 4 FXS is around $320 (to plug in 4 regular phones) SIP Phones cost between $60-500 with a decent business phone at around $200 Then there's the cost of PC and software setup and voIP services if needed. hth | ||||||||||||||||||||||||||||||||||
Posted by John Nelson on April 17, 2005, 6:27 pm
Please log in for more thread options anandsekar@gmail.com says... Start here: http://www.fwd.pulver.com http://www.fwd.pulver.com/support/configuration_guide | ||||||||||||||||||||||||||||||||||
Posted by on April 18, 2005, 2:56 pm
Please log in for more thread options Thanks ! | ||||||||||||||||||||||||||||||||||
Posted by Pepperoni on April 18, 2005, 3:00 am
Please log in for more thread options The simplest solution is to use a software peer-to-peer application between the two offices. Two PC headsets or handsets, and you're in business with *NO* further cost. If you want to interact with regular telephones, a simple Vonage (or similar account) with an added softphone for the second location would do. (the softphone has 500 outgoing minutes) Calls between the two accounts would not be counted. There are a lot of free peer-to-peer apps out there. Most offer prepaid minutes for calling regular phones at low rates. | ||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Simple VOIP setup | April 16, 2005, 7:51 pm |
| Setting up simple VoIP gateway | December 20, 2004, 12:05 pm |
| Seeking simple VOIP program | November 18, 2007, 12:24 pm |
| Simple VOIP help - Cisco 3620 outbound | December 21, 2004, 8:46 pm |
| Advice for a new VoIP Setup | June 30, 2005, 5:12 pm |
| voip phone setup | March 9, 2005, 5:46 pm |
| Setup a VoIP<--->PSTN Gateway | November 30, 2004, 5:27 pm |
| Need Advice for VoIP hardware setup | February 4, 2005, 3:48 am |
| Asterisk VOIP setup (on the office side) | May 20, 2005, 2:18 am |
| Small Office Voip setup - linksys ip pbx | August 7, 2006, 11:48 pm |
| simple rtp implementations | February 18, 2006, 11:20 am |
| Simple Win32 / SIP Library with API needed | February 4, 2005, 6:11 pm |
| A simple question, Ineen versus Paltalk | April 19, 2005, 12:21 pm |
| Simple static Jitter buffer dimensioning | February 23, 2006, 7:20 am |
| Want to Use Existing House Wiring ... however a simple test fails | January 8, 2006, 6:54 pm |
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language! Click Here to learn more |
Simple VOIP setup
Yahoo!
Windows Live
del.icio.us
digg
Netscape
