Voice-Over-IP Setting up a home IVR
Subject Author Date
Setting up a home IVR John McKenzie 05-16-07
---> Re: Setting up a home IVR Balwinder S \"b...05-16-07
| `--> Re: Setting up a home IVR Balwinder S \"b...05-18-07
`--> Re: Setting up a home IVR Wolfgang S. Rup...05-28-07
Posted by John McKenzie on May 16, 2007, 2:57 am
Greetings, all.
I am completely new to anything VoIP, other than client usage, so I come
here seeking guidiance.
If I can, I would like like to connect my home's PSTN line to my computer
and have my computer act as a voicemail system that reacts to call ID info.
What I envision is plugging a phone cable into the phone jack of my wall
and some piece of hardware that is connected to my computer (pressumably
by ethernet, USB, PCI slot, etc) and having the computer see the phone
numbers of incomming callers and acting on them. For example, if the
computer sees one number, it does nothing, if it sees another it plays a
recording asking the caller to leave a voicemail. Actually recording the
voicemail is good, but not absolutely neccessary. :-)
My research seems to indicate that the software part of this is possible.
I will eventually find something to put on my linux box for this purpose,
however, I am unfamilair with the hardware involved. I would appreciate
it if someone could advise if my goals described above are achievable,
and what type of hardware would I need for this.
I am unclear on what will do the job, but I know a little bit about what
is out there.
Would something like this item be helpfull in my above stated goals?
Grandstream HandyTone 488 Analog Telephone Adaptor
http://www.grandstream.com/ht488.html
It is relatively cheap, as such hardware goes right now, so I was hoping
I could just buy it, or something comparable, plug it it and run something
like Callweaver, YATE, SipX, etc to do what I desire.
Thanks
Posted by Balwinder S \"bsd\" Dheeman on May 16, 2007, 1:14 pm
On 05/16/2007 12:27 PM, John McKenzie wrote:
> Greetings, all.
> is out there.
IMHO, the Asterisk running on a Linux machine is a best option to meet
all your current and, or future needs and, or requirements. Instead of
an ATA (Analog Telephone Adapter), try finding a suitable card with one
FXS and one FXO ports.
Dr Balwinder S "bsd" Dheeman Registered Linux User: #229709
Anu'z Linux@HOME Machines: #168573, 170593, 259192
Chandigarh, UT, 160062, India Gentoo, Fedora, Debian/FreeBSD/XP
Home: http://cto.homelinux.net/~bsd/ Visit: http://counter.li.org/
Posted by Alphamacaroon on May 28, 2007, 7:10 pm
On May 16, 10:14 am, "Balwinder S \"bsd\" Dheeman"
> > Greetings, all.
> > is out there.
> Home:http://cto.homelinux.net/~bsd/ Visit:http://counter.li.org/- Hide quoted
text -
> - Show quoted text -
Don't waste your time on Asterisk. It's too difficult for the average
user. Check out http://www.callbutler.com.
Posted by LVMarc on May 17, 2007, 5:12 pm
> Greetings, all.
> is out there.
> Thanks
you can connect your pstn and voip using combine-a-line.
and it does not need a usb port and coptuer to operate savings 100's
dollars in wasted energy use.
here is a link to combine a line
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=020&sspagename=STRK%3AMESE%3AIT&viewitem=&item=300111295431&rd=1&rd=1voip
pstn zero enrgy use adapter avoid usb adapters
Posted by LVMarc on August 7, 2007, 6:56 pm
>> Greetings, all.
>> computer
>> info.
>> possible.
>> is out there.
>> something
>> Thanks
> here an important consideration when implementing a voip and pstn
servcie and back-up planning!
> Users of VOIP may want to consider back-up provisions to their
service. A user guide suggest what can go wrong and how to have a
back=up plan and lifeline in cases of VOIP in-operation.
> link to guide
http://reviews.ebay.com/Considerations-for-Backup-Telephone-Service-with-VOIP_W0QQugidZ10000000003684514
> Marco
> A review suggests how much power is used here.............
http://reviews.ebay.com/Billions-energy-savings-avoid-USB-powered-VOIP-adapter_W0QQugidZ10000000003599864
> A non usb pstn voip pstn adapter is located here
> a video of the operation of the Combine-a-line- (non usb) adapter is
here....
> View here and now.....http://www.youtube.com/v/R0aGKJQc7rc
> Thanks for viewing
> Marc
www.fwt.niat.net
http://www.youtube.com/profile?user=LVMarc
Similar ThreadsPosted
Setting up a home IVR May 16, 2007, 2:57 am
NTL and setting up VoIP (UK) October 3, 2004, 9:25 pm
setting up asterisk October 14, 2004, 5:05 pm
Need help setting up SPA-2002 September 23, 2005, 6:50 pm
Setting up SIP client questions (on Mac OS X) September 24, 2005, 10:44 pm
Time Setting on Mitel System November 8, 2004, 7:57 am
Setting up simple VoIP gateway December 20, 2004, 12:05 pm
VOIP in a small business setting July 27, 2006, 11:45 am
Guide to setting up your own VOIP service? July 17, 2007, 11:57 pm
home net voice over ip January 14, 2007, 8:08 am
HOME VOIP-PSTN September 21, 2005, 12:15 pm
Can I connect it to my home wiring? December 31, 2005, 1:45 pm
Voice over IP home service April 3, 2006, 4:08 pm
Calling from China to US, Can I install something on home PC? April 8, 2005, 8:58 am
Home Alarm Systems & VoIP August 11, 2005, 4:02 pm
