Voice-Over-IP SPA-3000 basic question
Subject Author Date
SPA-3000 basic question David M 06-30-05
Posted by David M on June 30, 2005, 1:42 pm
Hello,
I've got a SPA-3000 recently.
I disabled the possibility to switch from voIP -> PSTN when I want to
make a call and that the VoiP provider is down.
(I would like to avoid bad surprise on my phone bill.....)
However, I would like to force the SPA to use the PSTN line when I use
some specific number...
Is there a possibility to do this ? like ' *9 ' -> to use the PSTN Line
Thanks
Posted by Enzo Michelangeli on July 1, 2005, 7:48 am
David M wrote:
> Hello,
You mean if you dial some sequence from the telephone set connected to
the "Line 1" (FXS) port of the SPA-3000? Sure: just craft a suitable
dialplan in the "Line 1" panel of the "Advanced" admin setup. For
instance, this dialplan, a subset of the one I use at home:
...would result, by default, in calls to the PSTN (the "gateway 0"),
unless you dial "##" which will give you a dial tone (like dialing "9"
on some PBX's to get the external line) prompting you for digits to be
dialed through the main Voip account defined under "Proxy and
Registration" and "Subscriber Information" in the same panel.
To speed up the dialing and avoid a wait for digit timeout, just
terminate your phone numbers with a "#", just as it's normally done
when calling IDD.
Probably (but I haven't tested it) the behaviour you described above
would require this dialplan:
If you don't want a dialtone after the "*9", just take out the ","
after the "9".
Enzo
Similar ThreadsPosted
basic question April 25, 2005, 9:32 pm
basic SIP question June 9, 2006, 4:49 am
SPA-3000 basic question June 30, 2005, 1:42 pm
VOIP basic question! October 16, 2007, 2:41 pm
Linksys SPA3000 July 2, 2006, 9:49 am
Vonage and DSL basic August 29, 2004, 10:07 pm
Newbie to Asterisk some basic questions May 29, 2008, 5:12 pm
HELP! administrator manual for Siemens Optipoint 300 basic needed October 4, 2004, 6:17 am
Voip Updated Basic,Translating,Voip News and Advanced April 27, 2006, 8:43 pm
SIP VOIP Question August 30, 2004, 8:19 pm
ZyXEL ATA question March 24, 2005, 3:37 pm
VOIP Question August 10, 2005, 3:14 pm
question about sip stack August 14, 2005, 7:11 am
Newbie Question June 26, 2006, 12:18 am
Voip question March 23, 2007, 2:46 pm
