Voice-Over-IP SIP VOIP Question
Subject Author Date
SIP VOIP Question Mike Schumann 08-30-04
Posted by Mike Schumann on August 30, 2004, 8:19 pm
I'm totally new at VOIP. I thought I would test the technology by
downloading X-Lite from the Free World Dialup site. I got everything
configured, but I'm having mixed results getting things working. I can
sometimes get the test calls (to the 613 number) to work, but not very
often. When I schedule a call using the FWD site, the incoming call does
not arrive.
My computer is located behind a Linksys router. Do I have to change the
configuration in the router to forward any special ports (I thought SIP was
suppose to make things work thru NAT)???
If I do have to forward ports, how do I handle the situation where I have
multiple computer users on my LAN who want to use VOIP?
Thanks,
Mike Schumann
Posted by SPD on August 30, 2004, 10:18 pm
> not arrive.
Yep and nope. SIP has nothing to do with NAT. It is an application
that fails with NAT just like other protocols that carry network info
at the application level.
open port 5060 for signaling and the range of rtp ports for the audio.
which ones and which way depend on who initiates the connection.
You could try stun although I haven't used it. You could also put
your PC outside the firewall just to test before doing anything else.
> Thanks,
By the way FWD works well for me with an IP phone outside of my NAT
box.
Good luck.
Posted by Hank Karl on August 31, 2004, 6:15 pm
On Mon, 30 Aug 2004 17:19:01 -0500, "Mike Schumann"
>not arrive.
Try the other softphones that FWD offers. Also, make sure that the
softphone is configured for use behind a NAT (you may need to set up
STUN on the softphone)
Its not automatic. Check the FWD FAQ for using FWD behind a
firewall/router --
http://www.freeworlddialup.com/support/faq/networking
>Thanks,
Also, check out http://www.testyourvoip.com/
and http://www.voiptroubleshooter.com/
Posted by Adnan M. on September 4, 2004, 11:43 am
Check out the softphone at http://www.lanscape.com. look at Global iNet.
Voice quality and the suport really perfect.
Regards
> not arrive.
was
> Thanks,
> Mike Schumann
Posted by Randal Ziegler on September 8, 2004, 10:24 am
> Regards
> > not arrive.
> was
> > Thanks,
> > Mike Schumann
Just want to make a correction regarding Adnan's last post. The URL to
LanScape's web site is http://www.lanscapecorp.com
Look for the Global iNet VOIP service logo in the upper right of the
home page and click on it.
Randal
Similar ThreadsPosted
SIP VOIP Question August 30, 2004, 8:19 pm
VOIP Question August 10, 2005, 3:14 pm
Voip question March 23, 2007, 2:46 pm
Question about VoIP codecs February 20, 2007, 3:57 pm
VOIP basic question! October 16, 2007, 2:41 pm
question re ArtDio IPH-102 VoIP FXO FXS Gateway June 26, 2006, 3:08 pm
General VOIP question-Please read September 12, 2006, 10:09 am
VOIP network config question April 24, 2007, 12:27 pm
Question: PSTN to VoIP gateway options February 7, 2007, 8:53 pm
Cheap or VOIP Remote Call Forwarding Service question. November 7, 2004, 1:51 pm
ZyXEL ATA question March 24, 2005, 3:37 pm
basic question April 25, 2005, 9:32 pm
question about sip stack August 14, 2005, 7:11 am
basic SIP question June 9, 2006, 4:49 am
Newbie Question June 26, 2006, 12:18 am
