Voice-Over-IP Residential VOIP newbie questions
Subject Author Date
Residential VOIP newbie questions Jonathan 08-12-04
Posted by Jonathan on August 12, 2004, 1:07 pm
I'm looking at getting a Vonage phone line for my 1.5/768 ADSL circuit. I'm
completely new to VOIP though and have some questions:
1) How is the voice quality? Is it closer to cell-phone quality than POTS?
2) Are there delays or echos when making VOIP calls?
3) How much bandwidth does a VOIP circuit consume when idle and when in
use?
4) Can I have more than one line on my ADSL circuit?
5) Can I use my fax machine over a VOIP circuit? Will speeds be reduced?
6) What protocols and ports does the analog phone adapter use? I want to
know how to safely and properly allow this traffic through my firewall.
TIA for answering these. I'm really interested in pursuing VOIP service;
you can't beat the price!
thanks,
Jonathan
Posted by John R. Levine on August 13, 2004, 1:04 am
It varies a lot depending on how congested your net connection is.
When it's good it's very good, when it's bad, it's choppy and echoy.
The delay is unobjectionable, the echo is only bad when the voice
connection is bad.
>use?
At idle it's negligible, in use it's 90Kb unless you tell it to use
lower quality mode.
Keeping in mind the 90Kb per connection, yes.
Vonage says it'll work, but I haven't had much luck getting fax
connections to work reliably. I use my landline for the rare outgoing
fax, efax for incoming.
Having watched the traffic from the ATA 186, I see it uses DNS, NTP,
and TFTP to get booted. After that it mostly seems to be UDP port
5061 for control and 10000 for data. If you ask Vonage, they'll tell
you.
Posted by Jonathan on August 13, 2004, 7:40 pm
Thanks a bunch, this is the type of info. I really needed!
POTS?
> connection is bad.
> >use?
> lower quality mode.
reduced?
to
> you.
Posted by charlie3 on August 14, 2004, 12:02 am
Nobody knows they are talking to me on Vonage until I tell them
and I use the 50kbs medium setting. My broadband connection generally
give me 200kbs up and 3-4 times that down.
I have an occaisional glitchy call, too few problems to hurt my
enthusiasm for Vonage.
> use?
Vonage allows the customer to set 90, 50, or 30 kbs for call bandwidth
and if you put the vonage box between your router and cable modem the
box will reserve bandwidth for itself during calls. I'd guess Vonage
box uses negligable bandwidth or none when it's idling.
I am in a location right now where there are 2 vonage boxes, behind
the router, and we have not been having problems because of that.
I use efax so no experience with that.
I've written in other news group posts that I waited until i had a
cell phone before getting VOIP because the internet is not yet as
reliable as the traditional phone system. Vonage lets the customer
set up a phone number for forwarding calls during network outages and
a feature for simultaneous ring. I use the cell phone number for
both. For me Vonage is the right product at the right price.
Similar ThreadsPosted
Residential VOIP newbie questions August 12, 2004, 1:07 pm
RTP: Newbie General Questions November 27, 2005, 11:09 am
Newbie to Asterisk some basic questions May 29, 2008, 5:12 pm
Tips On DSL Connectivity For Residential VOIP April 24, 2007, 8:13 pm
how to record voip call for residential users? November 1, 2004, 1:39 am
VONAGE Newbie w/newbie question August 11, 2007, 9:40 am
voip newbie seeks help August 9, 2007, 2:44 pm
VoIP newbie seeks advice! April 14, 2005, 3:57 pm
questions about voip January 6, 2005, 5:18 pm
A couple of questions about VOIP December 16, 2004, 2:02 am
VOIP/Vonage/DSL Noob has DSL Questions January 23, 2005, 1:02 pm
Thinking about voip...a couple of questions December 3, 2005, 1:30 am
Questions on whether to switch to VOIP service July 17, 2006, 9:28 am
Newbie help pls! November 17, 2004, 1:21 am
Newbie March 13, 2005, 12:48 am
