Voice-Over-IP [Linksys 3102] Care to share a working config?
Subject Author Date
[Linksys 3102] Care to share a working config? Vincent Delporte 08-24-06
Posted by Vincent Delporte on August 24, 2006, 5:54 am
Hello
(FYI, I'm not using the WAN interface and the Linksys is connected to
the LAN using the familiar 192.168.0.0/24 plan, the PBX is sitting on
the same LAN, and no firewall is involved. This is straight PSTN ->
Linksys -> LAN -> PBX.)
No matter what I try, I still have the following road-blocks:
1. If I don't forward calls to the PBX through User 1 > Cfwd All Dest,
Linksys doesn't notify the PBX of incoming calls. Syslogd does show
that the Linksys detects the call. Using a dial plan under PSTN Line
doesn't work
2. When calls do get set, the internal extension can hear PSTN caller,
but PSTN caller can't hear internal extension : routing problem?
Since the 3102 doesn't come with any documentation and I'm told it's
sufficiently different from the 3000 that I shouldn't rely on
documentation for the latter... if some 3102 experts out there could
take a quick look at my configuration and what I tried and see if
there's something obvious missing/wrong, I'd be very grateful.
http://codecomplete.free.fr/linksys_3102_bad_config/
Thank you.
Posted by Enzo Michelangeli on August 24, 2006, 8:08 am
> Hello
(...which by the way is not done with the configuration you posted at
http://codecomplete.free.fr/linksys_3102_bad_config/bad_config_voice.html
> doesn't work
I think that the softphone mistakenly sends its RTP packets to a wrong
address or port. This could be due to some piece of equipment (e.g., the
PBX) using STUN to get the router's external IP address, and declaring that
one instead of the internal address (in the 192.128.0/24 network). This is
common practice to handle calls with peers ouside the NAT, but in your case
it would cause the loss of the RTP packets sent by the softphone...
Unfortunately, it's hard to tell from a distance. Why don't you try running
Ethereal (a.k.a. WireShark) to see what's going on? You may define a capture
filter like "udp and not port 53", just to avoid most unrelated packets.
Note: if you want Ethereal to sniff packets sent by the SPA-3102 to some
wrong place, you must use a non-switching ethernet hub (good luck to find
one in these days...). But in your case it would seem that it's the packets
sent by the softphone which are going astray, so they should be well visible
to Ethereal if it's run on the same PC.
The voice part looks identical to me... If I were you, I'd grab
http://www.sipura.com/Documents/SipuraSPAUserGuidev2.0.9.pdf and study it
carefully... The section 4.13 has various "Configuration Examples and Call
Scenarios" that were quite useful to me.
> Thank you.
At first glance it looks fine, although as I said it looks consistent with
the "second method" rather than with the one based on call forwarding. I
can't understand why the call is not passed to the PBX: you even register
the FXO on it...
By the way, Voxilla.com at http://voxilla.com/spa3kconfig.php has a useful
wizard to help in the configuration of SPA-3000 / SPA-3102 , which can at
least preset a few defaults. It assumes the use of a service provider, but
you can later adjust the server's name changing it into the IP address of
your PBX.
IIRC, you need to register before accessing it.
Enzo
Enzo
Posted by Vincent Delporte on August 24, 2006, 4:27 pm
On Thu, 24 Aug 2006 20:08:45 +0800, "Enzo Michelangeli"
>address or port.
Finally found what it was:
http://wiki.pbxnsip.com/wiki/index.php/Linksys_SPA-3102_FXS/FXO
Linksys "support" is beyond words, and I couldn't bear one more day of
staring at that interface ;-)
Thank you very much for your help, though. It did turn out to be a
routing issue.
Similar ThreadsPosted
[Linksys 3102] Care to share a working config? August 24, 2006, 5:54 am
[Axon PBX] Configuring the Linksys SPA-3102? August 12, 2006, 10:06 pm
[Linksys 3102/Axon PBX] Rewriting CID on the fly? October 17, 2006, 9:45 am
[Linksys 3102] Call group through VoIP? October 9, 2006, 3:54 pm
[Linksys 3102 + GrandSteam IP phone] Direct outgoing IP call? September 4, 2006, 1:37 pm
Share hotel room at Internet Telephony Conf., Ft. Lauderdale, FL January 22, 2007, 6:56 pm
Quintum config December 9, 2005, 6:01 pm
Quintum config June 22, 2006, 3:26 am
Lingo Config XTEN December 19, 2004, 2:52 am
Config Cisco 2611XM October 14, 2005, 10:39 pm
PAP2 config question November 26, 2005, 5:16 pm
Working out costings July 16, 2004, 1:15 pm
VOIP network config question April 24, 2007, 12:27 pm
Any way to get wep keys working with wifi Zyxel phones ? April 18, 2005, 4:00 pm
[A-Link IPU1 USB Phone] Working with X-Lite or X-Ten? October 6, 2006, 11:33 am
