Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on February 22, 2005, 7:49 pm
Please log in for more thread options Is there a consortium for IP licensing for use of GSMEFR,FR, AMR in telecom equipment? If not how does a company go about insuring it won't get sued at some point if they are using the GSM codecs in their products? | ||||||||||||||||||||||
Posted by Enzo Michelangeli on February 24, 2005, 6:28 pm
Please log in for more thread options You can ALWAYS be sued: at most, you can reasonably hope to win the lawsuit. Why don't you forget about GSM and use Speex (www.speex.org) instead? Enzo | ||||||||||||||||||||||
Posted by Tobias Erichsen on March 1, 2005, 5:07 pm
>> for use of GSMEFR,FR, AMR in telecom equipment? >> >> If not how does a company go about insuring it >> won't get sued at some point if they are >> using the GSM codecs in their products? >
> You can ALWAYS be sued: at most, you can reasonably hope to win the > lawsuit. Why don't you forget about GSM and use Speex (www.speex.org) > instead? Probably because there a few vendors in the market which support GSM but not many commercial ones who do so with Speex... Apart from that, GSM is computationally not nearly as straining as Speex is. Tobias PS.: And even using Speex you are not safe that someone might sue you because they think you infringe on their IPs... | ||||||||||||||||||||||
Posted by on March 3, 2005, 12:04 pm
Thanks, but use of the GSM codecs is manditory in our application. Anyone know if there's a licensing consortium or where I can find IP licensing info? (Note we have the software implementations). E.g. for G.723.1A you can go to sipro.com | ||||||||||||||||||||||
| Similar Threads | Posted |
| GSM Codec IP Licensing? | February 22, 2005, 7:49 pm |
| G.729 and G.723.1 CODEC API | February 24, 2006, 3:08 am |
| best codec | July 24, 2006, 11:38 am |
| Audio codec for G.729/G.723.1/G.726/G.728 | July 16, 2006, 12:05 pm |
| Microsoft RTC G.729 acm codec | August 10, 2006, 4:13 am |
| softphone with codec G.729 ? | April 2, 2008, 4:51 am |
| Hardphones with iLBC codec | July 22, 2004, 11:50 am |
| Testing Voice Codec | May 4, 2005, 12:24 am |
| 4GV Codec Reference Code? | March 29, 2006, 3:42 pm |
| Installing iLBC codec in Asterisk | December 16, 2004, 11:29 pm |
| Can NOT save file, unsupported Codec VoIP | August 2, 2005, 8:29 pm |
| Customized SIP and H.323 softphone with g723.1 and G729 codec | December 1, 2006, 3:19 am |
| how can I to play the Output file after decoded using ilbc codec? | November 7, 2005, 6:56 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
