Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Jason Kolb on May 10, 2005, 4:06 pm
Well, Avaya has gotten me into a bind. Maybe somebody out there has run into this before, it's worth a shot :) We have an internal outsourcer running Avaya IP phones and an S8300 with SLP. In the states, we have an S8700 that we need to use to run the IP phones (the S8300 is failover). Unfortunately and unavoidably we are getting latency times of about 315ms roundtrip to the remote site. This seems to be on the verge of acceptable, because the IP phones can sometimes register, but other times we are receiving an error "2011 IP FURQ-NoQ931 msg rcvd Force Unregistration Request". It seems to be extremely random. We called Avaya and it they said the registration confirmation is not getting from the phone back to the 8700 in a timely mannger. There are absolutely no firewall restrictions of any kind between the phone and the 8700. So what I'm left with is either finding a way to MAKE this work, or putting a bunch of really expensive equipment up on eBay :( We are looking for a way to override this behavior, either by extending the timeout or forcing the phone to register somehow. By the way, I'm willing to pay for advice that works... Thanks for any help you can offer!! Jason Kolb jason.kolb at gmail dot com | ||||||||||||||||
Posted by wkearney99 on May 10, 2005, 10:21 pm
Please log in for more thread options If you're expecting to get by on the cheap using the internet then you're not going to get it to work reliably. If you're outsourcing overseas then you'll have to deal with increased networking costs. Possibly even going so far as dedicated virtual circuits. It's not the equipment that's at fault here, its the network you're putting it on. | ||||||||||||||||
Posted by stephen on May 12, 2005, 12:30 am
Please log in for more thread options so it is worth working out what the "inherent" latency is between the locations - if you are close to that then you need to alter the topology. if you cant fix it, then you will need a more local call processor - maybe you can make the local 8300 the default and fall back to the remote processor? putting well sort of - but good network gear should not have built in limiting assumptions about bounded delay. (or at least if it does there should be something in the documentation). -- Regards Stephen Hope - return address needs fewer xxs | ||||||||||||||||
Posted by wkearney99 on May 12, 2005, 2:28 pm
Please log in for more thread options Given the nature of the application it's not like operating in a high-latency, or worse yet an inconsistent latency, situation is going to work reliably. Shifting from circuit-switched to packet-switched doesn't change the underlying need to reliable delivery of the data. If the underlying network can't deliver then no devices are going to work reliably. | ||||||||||||||||
| Similar Threads | Posted |
| Avaya Emergency - Any ideas? | May 10, 2005, 4:06 pm |
| Audio Loss (dropout) occurring with Vonage-using RoadRunner, Linksys, PAP2, etc.. Appreciate ideas? cannot hear me | February 10, 2006, 4:05 pm |
| Energy savings ideas and computations of VOIP PSTN adapters and genralized consumer products guide | February 18, 2007, 3:57 pm |
| Avaya and NAT | October 23, 2006, 4:57 am |
| Avaya Protocols | July 18, 2004, 9:54 am |
| How open is the "new" Avaya? | January 23, 2008, 9:27 pm |
| Avaya SIP Phone ConVersion | December 9, 2004, 3:31 pm |
| AVAYA X330-2DS1??? | March 22, 2005, 9:00 pm |
| Nortel BCM Vs Avaya IP Office | May 19, 2005, 6:36 pm |
| Which PBX to choose? Avaya or Cisco? | July 8, 2008, 12:01 pm |
| Which PBX to choose? Avaya or Cisco? | July 8, 2008, 5:58 pm |
| Avaya Soft Phone on Linux | September 27, 2004, 5:22 pm |
| VoiceGateway Solution con PBX Avaya Definity | September 17, 2005, 8:08 pm |
| IP PBX Advice (Nortel, Avaya, Mitel, Cisco) | October 15, 2005, 7:15 pm |
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language! Click Here to learn more |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
