Need help in troubleshooting our phones. They won't get an IP address and it appears they aren't even looking. Any thoughts? The switch has the vlans configured, I can send that if it helps. Thx in advance
no ip dhcp conflict logging ip dhcp excluded-address 172.28.55.1 172.28.55.19 ip dhcp excluded-address 172.28.55.251 172.28.55.254 ! ip dhcp pool 172.28.55.0_pool network 172.28.55.0 255.255.255.0 default-router 172.28.55.1 dns-server 192.168.30.2 192.168.30.3 domain-name xxxx.com option 150 ip 192.168.21.100 lease 8 ! ip domain name xxxxx.com ip name-server 192.168.30.2 ip name-server 192.168.30.3 no ftp-server write-enable ! ! ! ! interface FastEthernet0/0 no ip address speed 100 full-duplex no cdp enable ! interface FastEthernet0/0.1 encapsulation dot1Q 500 native no cdp enable ! interface FastEthernet0/0.2 bandwidth 100000 encapsulation dot1Q 501 ip address 172.30.55.1 255.255.255.0 ip helper-address 172.30.55.5 no cdp enable ! interface FastEthernet0/0.3 encapsulation dot1Q 510 ip address 172.28.55.1 255.255.255.0 ip helper-address 172.28.55.1 no cdp enable ! interface FastEthernet0/0.4 encapsulation dot1Q 1 ip address 172.25.1.2 255.255.255.0 ip helper-address 172.30.55.5 no cdp enable ! interface Serial0/0 bandwidth 768 no ip address no ip redirects no ip proxy-arp encapsulation frame-relay IETF ip route-cache flow no ip mroute-cache frame-relay lmi-type ansi frame-relay qos-autosense ! interface Serial0/0.1 point-to-point ip address 192.168.32.78 255.255.255.252 no cdp enable frame-relay interface-dlci 16 IETF ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto no cdp enable ! ip default-gateway 192.168.32.77 ip classless ip route 0.0.0.0 0.0.0.0 Serial0/0.1 permanent ip route 172.28.55.0 255.255.255.0 FastEthernet0/0 ip route 172.30.55.0 255.255.255.0 FastEthernet0/0 no ip http server !
