VOIP GSM GATEWAY - HG-4000 SERIES
Hypermedia Systems VoIP GSM Gateway for UMTS, GSM, CDMA and E1 / T1-PRI
are the leading professional equipment for total connectivity
solutions. The HyperGateway VoIP GSM Gateway line of products provides
a tailor-made solution for SMEs (small and medium-sized enterprises),
alternative carrier call termination and for call origination
providers.
One of Hypermedia VoIP products which have been recently launched,
called HG-4000vs, also belongs to the Gateway family.
HG-4000vs supports H.323. It is a complementary product to H.323-based
IP equipments and supports up to 72 GSM ports. By using HG-4000vs there
is no need for any external VoIP Gateways such as Cisco or Quintum.
HG-4000vs VoIP GSM Gateway main features:
    From 16 to 72 GSM ports
    Up to 288 SIM cards
    Advanced LCR and routing groups
    IP address and DDI pattern restrictions
    Remote pre-paid SIM recharge
    Integrated antenna splitter
    GSM worldwide use (850MHz / 1,800MHz / 1,900MHz)
    Redounded power supply
    WEB management and control
The HG-4000vs VoIP GSM Gateway fixed cellular terminal can be used not
only as a GSM Gateway but also for UMTS and CDMA (850 / 1900).
For more information on this company:
www.hyperms.com
Site Timeline
