Now with pictures!
- gregg dot drwho8 atsign gmail dot com
December 13, 2013, 3:26 am
Hello!
The selected entry on this page:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=42998&minisite=10251
for the RJ45S shows something rather simple, a typical connector and a programming resistor. Obviously the value of the resistor would be selected at the time the whole arrangement is wired.
However shown here:
http://www.shout.net/~wildixon/telecom/rj/rj45s.html
largely agrees with that one. And the matching one for the RJ41S which he has up shows a box marked PAD in the connector:
http://www.shout.net/~wildixon/telecom/rj/rj41s.html
What I am asking about is one of, has anyone ever seen one, and would then know what is inside that box?
Gregg
"This signature was present during the destruction of Troy, and knows where it happened."
However shown here:
Gregg
Re: USOC RJ45S questions
For a more complete explanation of the uses of these RJ jacks (and
others), take a look at this webpage:
http://www.arcelect.com/RJ_Jack_Glossary.htm
RJ-45's were/are used extensively with dial-up modems, especially
where RJ-11 operation would be unreliable. I have seen hundred's of
them. RJ-41's less so.
a typical RJ45 would look like this:
http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=40278-I§ion=39419&minisite=10251
with the resistor added at time of installation.
RJ41 would be similar but larger with the FLL/P switch.
BTW, the term "RJ45" existed in the telephony world long before
Ethernet 10Base-T came along. The Ethernet LAN people usurped the term
just because they happened to use the same physical 8pin hardware.
Site Timeline
- » Panasonic KX-T7431 password
- — Next thread in » Telecom Technical
- » WE 2500 buttons do not make tones
- — Previous thread in » Telecom Technical
- » Ringback number needed in Maryland/Verizon (410) (443) (667)...
- — Newest thread in » Telecom Technical
- » FCC tries to bury finding that Verizon and T-Mobile exaggerated
- — The site's Newest Thread. Posted in » General Telecommunications Forum
