With a shoe on the line that has continuous ring on it? No dialtone... just a blast of loud 20 Hz in the ear.
I never worked for a LEC, and hence rarely ever worked on POTS subscriber lines, but 20 Hz continuous ringing did have other uses. Originally it was available on
2-wire testboards (18B Testboards were the ones I worked at) that interfaced with cable heads. There was a front row of cords and a back row, and one particular key labeled RING of course, could be pushed forward or backward to connect ring current to front or back cords as desired, with the cord inserted into the Primary Jack for any given cable pair one wanted to "ring".The typical use we found for this was with a lot of the leased lines using those new fangled things called modems, instead of teletype loops (which had anything from 20ma to 60ma of current pulsing on them all the time).
Seems that every now and then a leased line with no current on it (no loop current or no teletype current) would get a static charge built up on the line, and it would simply go dead, with no continuity for the voice path. Most of the time just putting a test set on the line would clear it, but we discovered that a 100% guaranteed fix was to zap the line with a few seconds of ring voltage! So that became pretty common... until most leased lines began to be equipped with "sealing current" modules to avoid the problem.
